hey guys, i can't believe i've had my car for almost a year now and i only JUST noticed that i have a little green plug up front that's unplugged!!
Everything in the car works ok, except for my boost gauge...but i'm confused as to wtf that little green thing is supposed to do?! is it simply the connector to make the boost gauge work? i didn't just want to plug it back in without knowing what it's supposed to do first...
https://www.sau.com.au/forums/topic/132509-what-does-this-green-plug-do/
well that's what i thought too but the temp gauge is working..
in my car, thats a sensor to switch the thermo fan to the higher speed
but you have a clutch fan, so im not really sure
someone with an r33 should be able to help you
I'm pretty sure that plug connects the thermo fan on the front of the radiator, which only comes on when coolant/engine hits a certain temp - nothing to do with the boost gauge I'm afraid.
Perhaps check to see if the MAP sensor for the boost gauge is also disconnected (little black box tucked away down the back of the engine bay in the driver-side corner)...should have an electrical connector and a vacuum hose connected.
It plugs into the other green plug, on the radiator!!!! That leads down to the thermo switch in the bottom tank that tells the A/C thermo fan (the one out front of the radiator) to switch on when the coolant starts to get a buit too hot.
Thats the connector for the thermo switch that turns the sub cooling fan on. Its an extra fan incase the engine is idling and the clutch fan isnt doing enough revolutions to create sufficient airflow to cool the engine coolant. I think it also comes on when you switch your AC on, but my AC has never worked so i cant back that up. But it would make sense as there is no way of electronically switching on a heat activated clutch fan!
Thermo fan man. That's where mine goes, and I have to unplug it to take the radiator out. If you've had the timing belt changed or something like that recently, then someone left it unplugged.
Does the A/C condenser core have a seperate fan to the one we're talking about???
man what's going on... in that pic you sent there's clearly another plug that it goes into... did you not see it??
lol, true true, we all saw it, but no one stated the obvious.
just plug it in, it's even colour coded. then whatever it does, it'll do it. done
i think you're right on the money, i had the timing belt and water pump replaced a few months ago and they probably forgot to plug it back in..
and yes i was going to plug it back in but i just wasn't sure what it would've really done
thanks for the feed back guys!
    • What could be causing my clutch problem besides a bad master or slave then? Both those parts are new
    • Just came across this, but in QLD I start leave again in 2 weeks, if it is still available I might drive up and check it out Unless, @MBS206 do you live near here????, if so I could hit you up with a finders fee https://www.gumtree.com.au/s-ad/hope-island/auto-body-parts/nc-mx5-factory-hard-top/1328976391
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
