Hey guys, just got a bosch 040, and ordering in some injectors soon. Out of the listed mods, which can you install without adverse affects?
with my current mods, could i install the fuel pump, and injectors etc on the stock ecu and get away with it, or is it best to do all at once?
I am curious to how exactly your going to run with the z32 and bigger injectors when you still have the stock ecu on an auto?
I have the same problem with ecu, thats why I got a remap.
I wonder if another remap could support the bigger injectors and z32?
im not planning on a rebuild....but when the time comes, i guess i have no option.....imin the process of getting a manual box right now:)
You might not get much of a choice when you start hitting big figures. Price up some 20thou Arias forged pistons, adjustable cam gears, cometic head gasket, full bearing and gasket kit, ARP studs etc. Once you have that done you can add on whatever you like without the worry of putting a rod through the block or melting a piston. Worth the piece of mind IMO.
    • @DraftySquash @Duncan he's not talking about the part that sits against the radiator support, he’s talking about the lip that sits towards the front outside of the car. anyway I had a look at other cooling panels and came across this one https://justjap.com/products/carbing-radiator-cooling-panel-plate-nissan-skyline-r34-gt-t?variant=37829684134087&currency=AUD&utm_source=google&utm_medium=organic&utm_campaign=Advanced feed&utm_content=Carbing Radiator Cooling Panel Plate fits Nissan Skyline R34 GT-T (Coupe)&srsltid=AfmBOoonzPDKqe9NgKi5U0AkFc2XvbXETGmNWvfNcyBT5DUZagMYHg9DZ70 if you take notice it’s the same shape.  well thankfully the justjap listing has a description and it says : - Nissan Skyline R34 GT-T Coupe (M/T -07/2000) this means it’s specifically for a s2. S2’s have different front bars to s1 so that lip with the 3 holes are *probably* mounting points for the s2 bar. im not 100% sure but im almost certain it will still fit a s1 bar
    • Everyone is too used to learning from places like HPA "how to tune" and what to expect at what point, rather than being able to see "The computer says I'm in cell with Row = 8, column =4, and I can see my fuel is lean, so lets add more" Everyone wants "real units", which helps for someone picking it up for the first time and seeing how bad the tune is if they're not used to touching it.   However, I think for most of us who want to play with it, you're 100% right, we're only needing to learn about it for OUR CAR. Which makes it great, and we don't need to care what the real values are, we just need to know which cell it is, that's causing the lean or rich point, or that we want more ignition timing or less. But again, everyone wants everything super you beaut and nearly self tuning, with VE maps, and a billion compensations...   Though then there's me over here when I'm doing reverse engineering work just reading data in hex format that most people couldn't work anything out from. Yet I can see what's going on.
