  • Replies 152
Posted Images
Ive got an rb25 sitting here, got the forged pistons and all the bits but the car would just be another r32 with an rb25 in it .I like the idea of the rb20 as there are no really quick rb20's getting around that I know of , you go to the drags or a track meet and if its got an rb25 in it people expect it to be quick .The last couple time's I ran the old black car at the drags the amount of people that came upto me thinking it had an rb25 or 30 in it was amazing and were quite shocked to find it had an rb20 in it and run consistant 12 second passes.So its a bit of a challenge ive set myself to get it to run an 11 sec pass in street trim .The 25 can always go in later after I've acheived my target pass "maybe" :-)
https://www.sau.com.au/forums/topic/132547-again/page/2/#findComment-2563487
Hi Silv
He does do wheel repairs but there was no damage to mine, just had to sandblast the chrome of and and respray them and that was $125 a wheel mainly cause of the sandblasting
Cheers Peter
https://www.sau.com.au/forums/topic/132547-again/page/2/#findComment-2582988
Another weekend spent working on the car results are starting to be seen base coat applied and looking nice and straight
post-7066-1162699366.jpg post-7066-1162699385.jpg post-7066-1162699407.jpg post-7066-1162699434.jpg
post-7066-1162699458.jpg post-7066-1162699486.jpg post-7066-1162699510.jpg post-7066-1162699531.jpg
Still looking for type M side skirts If anyone's got any :laugh:
Cheers Peter
https://www.sau.com.au/forums/topic/132547-again/page/2/#findComment-2642827
hmm.. thats really coming up nicely!! :)
great thread. after years of rebuilding classics, i know the work involved here....oh by the way great colour.
bernie/uk super clear red 33gtr
Edited by rockabilly
https://www.sau.com.au/forums/topic/132547-again/page/2/#findComment-2644079
Ok
Goodies off tomorrow to the machine shop to get block bored and all measurements done for acl race series bearings be about three weeks b4 I get them back but its a start on the engine at long last most parts are here
Just a quick pic of some of the parts I'll give a rundown
post-7066-1162880133.jpg nismo fuel pump
New crank collar fitted and crank all balanced up by proengines thanks greg :)
and rods all done shotpeened and hardned resized and new gudgen bearing's
post-7066-1162880207.jpg new performance valve springs
post-7066-1162880236.jpg arias forged pistons 79mm
post-7066-1162880258.jpgpost-7066-1162880361.jpg arp main ,rod, and headstud kits
post-7066-1162880279.jpgpost-7066-1162880299.jpg nissan n1 water and oil pumps water pump of blitz thanks Nick
post-7066-1162880320.jpgpost-7066-1162880345.jpg tomei oil restrictor's and nismo thurmostat of slide thanks Aaron
post-7066-1162880534.jpg tomei metal head gasket from UAS thanks John
Once it all come's back I can start with the assambly :PBJ:
Cheers Peter
https://www.sau.com.au/forums/topic/132547-again/page/2/#findComment-2648560
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
