  • Replies 152
Posted Images
  • 1 month later...
Hi Guy's and gal's
Been a while since I've updated this been busy with work and flat out on the car but painting's finished so I thought up update with couple pic's of the near finished product, engines still a ways of as its still at the machine shop they have a xmas rush on too so that might still be a while
post-7066-1166320680.jpg post-7066-1166320707.jpg post-7066-1166320735.jpg post-7066-1166320759.jpg
post-7066-1166320785.jpg post-7066-1166320812.jpg post-7066-1166320842.jpg post-7066-1166320868.jpg
Glass hopefully will be going back in this week so then i can get stuck into putting it back together over the break .I wish all a merry xmas and happy new year
Cheers Peter
https://www.sau.com.au/forums/topic/132547-again/page/3/#findComment-2755633
Well at a bit of a standstill atm just waiting on engine back so I can assemble it and parts from japan but here's where im upto starting to look like a car again front blinkers look awesome thanks Nick
Will update again when I get to the mechanical side of things
Cheers Peter
https://www.sau.com.au/forums/topic/132547-again/page/3/#findComment-2784150
I'mm getting there ,Imm getting there, damn machine shop's ,still waiting on me engine parts back promised me b4 xmas but still no engine :D but at least the body's near done .
Bet that feels good hey Moanie to have your pride and joy back after so long how's it going ?????
https://www.sau.com.au/forums/topic/132547-again/page/3/#findComment-2786583
lol! i understand that frustration! :) majority of delays on my car were the machining shop :) they took AGES!!!!! then got sick.. then took another AGE!!!!!!!!!!!!!!!!!!!!! :D
and yeap! it feels awesome to be driving again!!!! :P still got another 1000kms of slow time, but my 55rwkws are more than i can handle for the moment! ;)
https://www.sau.com.au/forums/topic/132547-again/page/3/#findComment-2786986
  • 4 weeks later...
  • 3 weeks later...
Well after alot of friggin around with putting in the rb25 crank and a trip back to the machine shop for some more modification to the block, assembly has started here's some picks of the block b4 modifying it
here's some pics after modifing modification with a close up of cut out made to block
here's arp mains installed and king bearing's
crank all installed and arias pistons on rb26 rods ready to go in
Now this is what i've been waiting for bottom end assembled
here's where all the time went into head modification
rear oil return from back of head porting inlet and exhaust manifolds and flowing the head
and a set of 1mm oversized valves the head flowed at 255 hp n/asperated so will flow pleanty with forced induction
and here's where I'm upto now waiting on a sump to be made , and when I can find the bolts for the oil pump and water pump I'll put them on
cheers Peter
https://www.sau.com.au/forums/topic/132547-again/page/3/#findComment-2900754
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
    • I can donate $100 to your upgrade fund. So long as you can donate the IC7 my way....
    • I'd love a Haltech ECU, and Haltech 10 dash. Was having a chat with Rob and Andy @ Haltech when Rob put one in his MR2. First one I'm kind of interested in too, as you can dim it RIGHT down. Andy was saying bright dashes is one of his peeves too!
