  • Replies 152
Posted Images
  • 1 month later...
Hi Guy's and gal's
Been a while since I've updated this been busy with work and flat out on the car but painting's finished so I thought up update with couple pic's of the near finished product, engines still a ways of as its still at the machine shop they have a xmas rush on too so that might still be a while
post-7066-1166320680.jpg post-7066-1166320707.jpg post-7066-1166320735.jpg post-7066-1166320759.jpg
post-7066-1166320785.jpg post-7066-1166320812.jpg post-7066-1166320842.jpg post-7066-1166320868.jpg
Glass hopefully will be going back in this week so then i can get stuck into putting it back together over the break .I wish all a merry xmas and happy new year
Cheers Peter
https://www.sau.com.au/forums/topic/132547-again/page/3/#findComment-2755633
Well at a bit of a standstill atm just waiting on engine back so I can assemble it and parts from japan but here's where im upto starting to look like a car again front blinkers look awesome thanks Nick
Will update again when I get to the mechanical side of things
Cheers Peter
https://www.sau.com.au/forums/topic/132547-again/page/3/#findComment-2784150
I'mm getting there ,Imm getting there, damn machine shop's ,still waiting on me engine parts back promised me b4 xmas but still no engine :D but at least the body's near done .
Bet that feels good hey Moanie to have your pride and joy back after so long how's it going ?????
https://www.sau.com.au/forums/topic/132547-again/page/3/#findComment-2786583
lol! i understand that frustration! :) majority of delays on my car were the machining shop :) they took AGES!!!!! then got sick.. then took another AGE!!!!!!!!!!!!!!!!!!!!! :D
and yeap! it feels awesome to be driving again!!!! :P still got another 1000kms of slow time, but my 55rwkws are more than i can handle for the moment! ;)
https://www.sau.com.au/forums/topic/132547-again/page/3/#findComment-2786986
  • 4 weeks later...
  • 3 weeks later...
Well after alot of friggin around with putting in the rb25 crank and a trip back to the machine shop for some more modification to the block, assembly has started here's some picks of the block b4 modifying it
here's some pics after modifing modification with a close up of cut out made to block
here's arp mains installed and king bearing's
crank all installed and arias pistons on rb26 rods ready to go in
Now this is what i've been waiting for bottom end assembled
here's where all the time went into head modification
rear oil return from back of head porting inlet and exhaust manifolds and flowing the head
and a set of 1mm oversized valves the head flowed at 255 hp n/asperated so will flow pleanty with forced induction
and here's where I'm upto now waiting on a sump to be made , and when I can find the bolts for the oil pump and water pump I'll put them on
cheers Peter
https://www.sau.com.au/forums/topic/132547-again/page/3/#findComment-2900754
    • Be more active mate.. , not taking the piss ❤️, your long term health will love you for it I would think something like a kettle bell or 2 laying around in areas you go past during the day would be awesome for ADHD.... "Oh look, a kettlebell", and exercise helps your brain health as well My mates son was a bit of a problem child, diagnosed wirh ADHD, and some other things that had his brain occasionally doing loops, until we got him into a training program, the difference after he started training was amazing, he had more focus, and his fitness levels exploded, it is like he is a totally different kid to be around Brain chemistry something something Stay fit stay strong mate
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
