Dude you dont need 750rwhp in a GTR to run a 10.50 or faster, where do you get your information from?
You can do it will less than 600rwhp
re: crank
Its not so much the outright RPM... its a combination or RPM and Load, my bet, the motor dies
  • Replies 40
to make a thousand horses you just need a thousand shot of nos.. :O
Or build a full jun or hks stroker bottem end. Two T04z's or a big 1200roller bearing turbo, some decent headwork and everything else to support... Should be rite.
re: crank
i reacon i could do it with less that 600rwhp aswell. i dont need that much power to run the times i want but i want power, and i can safely say that i know a whole heap about wat im getting myself into because everything im doing has been done with alot of thought, expert advice and alot of hard earned money. i'v run 11.7 @ 118mph with only 360hp on a real crap ass tune on 1 bar with 2530's full weight with 2 amps and a sub box in the boot, that day i wasnt even meant to run it but i did purely for the fact that my mate had a spare helmet, i was there and felt like racing. this car isn't a designated drag car its a "STREET" car but i would like it to run fast on the track. the engine WILL go cactus, but wen that happens i will get a billet crank.
so will my standard crank handle 10,000 rpm.
So much money, so much foolishness. I agree with nxtime and probably everyone else who reads this. 10,000 on a standard RB26 crank...go aftermarket and save yourself the pain.
re: crank
414awkw 26psi (C16) will net you a 10.3*...we did it and im a crappy driver....we only used 34psi 467awkw for dyno queen comps.
I've just bought a complete Trust T88-38GK kit for my R33,stock crank,Tomei rods,Arias pistons,Jun oil pump,Tomei head gasket,Ross balancer etc.
Should be going in a week or 2,will post up results in RB26DETT section.
Previously made 370rwkw with HKS 2530's on 100% standard internals from the head down.
I will only rev the motor to 9200rpm,hoping crank will be OK.
i wouldnt worry about the crank id be more worryd about the block r26 blocks are nortorius for cracking or spliting bores
yes someone with sense, with the standard 86mm bore i only took it to 86.5mm and in an attempt to make it stronger i got the block cryogenically frozen but ppl say that all that has done is make it weaker but ye the info i got from the mob who do it they say it makes it stronger and i also got the crank cyoe'd aswell as a precaution.
sweet man that sounds nuts, when will it be up and running let us know how u go, mine should be ready to go within the nxt couple of weeks il post my results, after the run in, another question 4 u guys. everyone has their own theories, some ppl say to run the engine in lightly with oil changes every 500 upto 1500km, some ppl say jst load it up on the dyno on and off until fumes stop coming out the breathers and then dump the oil and go for it. from various experiences we load the cars up only a little bit on the dyno until the breathers are clear and then go for 500km, dump the oil, go for 1000km then dump that lot but during that 1500 driving to only 4000-4500rpm and little if no boost at all, then after that put in the synthetic and go 4 it, and that so far has proved to be very effective with every engine we'v built, wat do u guys reacon from personal experiences is the best was to "run in" a new engine. personally i think the way i explained has proven to be the best i thought id add it in so others could benifit from the 100% effective advice.
    • I'm seeing torque specs all over the place for the OUTER tie rod, but none for the INNER tie rod, where it connects to the steering rack. Even in videos, people are just tightening em up as much as they can with a wrench and that's it. Anything tightened down without torque makes me nervous. Anyone know what the spec is for it?
    • Hope you had a great time here in our tiny country.   The JDM scene we have here is quite small, it's mostly BMW, Volkswagen with burble tunes haha. But the few JDM cars we do have in the scene are pretty nice. Some of my friends drive cool s14's too. Both built engines, red one makes abt 500, blue one abt 400 i think?
    • Ye good idea , would have never thought of something like that. Might aswell do it to every pulley and the balancer while I’m there
    • Use an LS1 or similar, via kit like Frenchy's. But.... It's probably not the alternator. It sounds like belt squeal, which would be because the pulleys are glazed. Rub every groove on the pulleys with 120 grit paper. Report back. Oh, and new belts afterwards too. The old new ones will be shitted up already.
    • Hello all I have 2 r34 sedans , one turbo one na, only recently aquired the na 34.  Man what is with these things.... My turbo 34 started sounding like a super charger, it was screaming at anything above 4000rpm , I took the alternator apart and replaced the front bearing which is the only one I think you can access and it did not fix the issue so presumably the bearing in the rear of the alternator is gone. ( diagnosed it was the alternator by taking off the aux belts one by one to figure out which pulley or bearing it was )  My friend gave me one he had lying around, Installed it , it did not squeal for maybe 500kms and now its started to squeal again briefly on startup  Recently got an na r34 and I replaced the timing belt, water pump + all the auxillirary belts. Runs amazing but it suddenly developed the same squeaking problem but significantly worse, Ive had my neighbour come down screaming at me because it was waking her up everytime I moved the car. It takes a good 2 minutes before it quietens down.  Im yet to diagnose where its coming from but im fairly sure its coming from the alternator aswell. My question isnt about how to fix it but rather where can you get a new alternator for an rb25 neo??? Ive searched everywhere but I havent been able to find a direct fit oem type replacement thats not genuine. All the automotive stores sell an oex one - BXA035 - which I picked up for cheap through a friend with staff discount , got it home only to find the connector is completelty different.... As far as im aware bxa035 is for rb20/30's and after a bit of figuring out the bxa035 has an ev14 type connector, which is tiny compared to the rb25 connector. I actually had an ev14 connector lying around which I was considering just replacing the bigger plug with to get the alternator working but the bxa035 is rated for 70amp vs the rb25 alternators are 90amp ( or so ive been told ? ) That paired along with the fact im about to install an amp + sub in the back and I have the stock sized small battery Im not sure itll do the job unless anyone has another opinion?  I know and have seen all the websites selling the ls1 alternator conversion kit but I am not going down that route, nor do I have the money to. Hopefully I can figure out how to get 2 brand new alternators for both cars. I would buy second hand which there seems to be many of but considering how common this seems to be im sure If I installed a second hand one it would start squealing in no time  Or even better if anyone knows how to fix the issue directly with the alternator itself... Any input appreciated Thank you     Link for bxa035 connector picture
