hey guys,
i was looking at buying a gt35 40 for my r33 and just wondering is ity going to have big lag ay i only have a fmic, xorst, airfilter and walbro pump, im planing to go biger injcectors computer but how will it run stock? i dont want it to have heaps of lag.
https://www.sau.com.au/forums/topic/132659-gt35-40-big-lag/
  • Replies 43
from what ive hurd on here you would be looking at about 4000 b4 boost
Consider the GT3540 .63? I'm sure SAU needs a guineepig. :laugh:
If you have a look at garretts turbine maps you will notice the GT35r .63 and the GT30r .82 have similiar flow/pressure values. I'm not completely sure and won't be for a long time but to myself the GT35r .63 I feel is a better option over the GT3040r .82 as the larger gt35r turbine wheel provides more shaft torque to drive the compressor.
I would be interested to see if any one has gone the gt35r .63 route over the gt3040r .82.
I'm a little scared of lag to be honest. I wouldn't go any bigger than a gt3071r on an rb25 but that also means reduced power output. :)
https://www.sau.com.au/forums/topic/132659-gt35-40-big-lag/#findComment-2458472
GT35 - .82 = boost (15-17psi) after 4500rpm or possibly even later than that,l its a 700hp turbo for gods sake.
Before that dont expect anything special and it will be quite lazy about town :)
DOnt get a GT35, get a GCG hi-flow or something similar if you want response
https://www.sau.com.au/forums/topic/132659-gt35-40-big-lag/#findComment-2458778
That is wright it doesnt come on til about 4000rpm i run one on my R33, ive been told you can put a smaller rear housing on it which would bring it down a bit. But for round town driving it pretty good you can still drive normally without ur BOV going off every time you go through the gears and when you want the power it comes on hard.
https://www.sau.com.au/forums/topic/132659-gt35-40-big-lag/#findComment-2459352
My .82 GT35R hits full boost (15psi) at 4600rpm.
FJ20ET stock, not mine (mine is FJ20E :P), full boost 18 psi at 4750rpm and 1 bar a 4500rpm. Mine same thing though 25 psi at 4750rpm. Running 0.82 housing.
Being a 6 with 2.5L, probs around the 4500rpm mark. Woohoo, turbos dont usually make good power till before this rpm anyways. Youll be surprised as to how nice it is. But yeah response wont compare to GCG high flow. But get a 3540 :( I love it
https://www.sau.com.au/forums/topic/132659-gt35-40-big-lag/#findComment-2459494
Im running a GT35r with .63 a/r on my rebuilt Neo Rb25 and its not laggy at all. Mind you its has been rebuilt and hiflowed by GCG but yeh i am very impressed with the response and accelaration
The Gt35r turbine wheel is too large to fit in to any of the hitachi/garrett internal housings that I know of.
I would assume you are running external gate?
https://www.sau.com.au/forums/topic/132659-gt35-40-big-lag/#findComment-2459820
Well u must be mistaken as it is definately a gt35r in garret housings. Everything was modded. It was originally a t4 (specs unknown) and i got it rebuilt by gcg with ball bearing and hi flowed with .63 a/r. Spools up real quick
Yes running turbosmart ext wastegate and turbosmart supersonic bov (sleeper series) with an ebc on the way once it gets full tune
https://www.sau.com.au/forums/topic/132659-gt35-40-big-lag/#findComment-2460088
not taking the piss out of anyone, but i think the word 'hi-flow' really is being used quite a lot these days, sometimes for the wrong reason.
xxx_25L,
if you don't want too much lag, you can go with a GCG 'hi-flowed' turbo which will make things easier while fitting.
another option is a Garrett GT3071R with an A/R .82 exhaust housing which would be reponsive enough given the smaller compressor wheel, and plenty of flow given the A/R .82 exhaust housing.
https://www.sau.com.au/forums/topic/132659-gt35-40-big-lag/#findComment-2460140
So your definitely not running the usual RB style turbine housing.
It must be something along the lines of a VLT housing.
OR... have you miss-used the world 'highflow'? Highflow uses your origional turbine and comp covers.
As you are running an ext gate I think it would have been silly for GCG to machine up a T3 .63 when garrett sell a T3 .63. I think you will find it isn't a highflow but rather a good ol' genuine GT35r .63.
Got the receipt? Would be keen to see how they have worded this highflow which clearly isn't a highflow. :(
https://www.sau.com.au/forums/topic/132659-gt35-40-big-lag/#findComment-2460206
Got the receipt? Would be keen to see how they have worded this highflow which clearly isn't a highflow. :)
Ok to clear up...My original turbo WAS a T04 (specs unknown - roughly rated at 450hp ) I got gcg to convert it to a gt3540r using my original housings...you comprehend???
Below - quote by Michael Ramsay from an email.
"The GT3540R core swap is about a 6 hour job, where adaptors plates need to be welded and machined and tapped to the turbine housing, and some extensive machining and modification is required.
The GT35R Conversion - Rated between 600 & 650 using customers housings.
Kind Regards
Michael Ramsay
Internal Sales
GCG Turbochargers Australia Pty Ltd
Phone:+61 2 9708 2122
Fax:+61 2 9708 2912
www.gcg.com.au
Est 1979
Edited by FSTR32
https://www.sau.com.au/forums/topic/132659-gt35-40-big-lag/#findComment-2461975
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
