I have purchased all the parts myself and have done all the work up to needing a hoist. I'm paying a workshop to do the work that needs a hoist and set the clutch system up so I can drive it home then I will finish it off.
It will end up being around $3,000 - $3,500 not including the centre console. I will work that out later ether moding the auto one, making up a new one using the auto one or maybe buy a manual one if that won’t work.
Edited by Burns
I just got the pun about the "manual in the stag."
Some of us (ie. me) are a bit slow around here.
Maybe that's what they mean when they say auto's are a bit slow on the uptake...and I thought it was just the cars, not the owners!
Age is finally catching up with me.
Edited by 3intheBack
Wen i got my auto S1 it had a manual in the glove box. Effffiiiinnn HAHAHAHA!!!
The more I drive the auto, it seems the better it gets. I think I saaid it before some where but the Stagea is a VERY responsive Auto. I think better than any other auto i've peddaled.
You touch a Stagea in the right place and she EXCITES. She has a wisdom beyond her years!
I read a great quote on the forum... GOD created turbo lag to give V8's a chance.(and all those other little shit boxes that try to pass themselves off as real cars) STEALTH IS WEALTH. :P:(
Burns, there are some things you just shouldnt own up too...
I know this is your bike, 'cause you kids wouldnt be seen dead on it.
It really is my bike, I don’t have kids. I have a KTM200EXC as well but don’t think I have any pics.
The back up car was having brown outs today. With the head lights, rear demister, fan and wipers going the radio would drop off if the revs dropped or I used the brakes and the blinkers and brake lights wouldn’t work at the same time.
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
