The exhaust temp light on my gtr has been flashing sometimes for a little while now, usually when going up hills under load.
But on the way home tonight the exhaust temp light was flashing even under really light throttle between 2-3000 rpm and also a tick happens which sounds like something in the rocker gear but only ticks when the light is flashing.
Its got me stumped and pretty worried. If anyone could help that would be great.
https://www.sau.com.au/forums/topic/132670-wierd-gtr-problem-help/
Just started it up when it was cold let it idle for a couple of mins, revved it between 2-3 grand, no tick or light.
took it for a drive, when it gets hot light flashes and tick comes back only when light is flashing.
So i guess it cant be a rocker/lash adj prob cos it would tick all the time?
Any GTR experts out there?
do you have a PowerFC computer? It uses the engine check light to warn of excessive pinging....sounds like what you are describing
The standard ECU is different it is cat overheating warning.
Got 2 opinions. One said its pinging so i got new plugs,fuel, octane booster and retarded timing just to be sure. Still there.
Then someone whos had a fair bit experience with RBs had a look at it and said it sounds like a shim issue on the inlet side. At least it's not big end cos i was starting to think it was.
Gonna take the rocker covers off and suss it out 2moro.
well the engine light is definatley the knock warning on a PFC. But is is possible that the noise that the sensors are picking is something other than pinging.
On the other hand....if the main time you are getting it is when you are going up hill under load.....
HI MAN
THE ENGINE LIGHT IS TELLING YOU THAT YOU ARE EXCEDING 60 ON THE KNOCK,THIS COULD BE DUE TO ENGINE RESONNESS,HITTING REV LIMIT OR ALSO PINGING.MY GTR GOES TO 45 AT REV LIMIT AND IF I PUT IN MORE TIMING ADVANCE IT EASLY GOES OVER 60.GOOD LUCK FINDING PROBLEM AND PLEASE LET US KNOW WHAT WAS CAUSING YOUR PROBLEM
STUART
Just checked all clearances and condition of shims. They're all within specs. I've got a nasty feeling its a big end knock and the sensor is pickin it up.
Anyway i've done all i can so i'm prob gonna take it down to Morpowa next week and let them suss it out.
Got it back from morpowa today after having it there for 2 days they reckon its a problem with number 5 or 6 piston. Probably a broken ring land or gudgeon pin issue.
I'm gonna pull it out this weekend or the next and strip it down.
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
