last night i did a 52.754.
couldn't be bothered doing it anymore..... until someone goes faster. now i'm going to see what the fastest lap i can do is. my current best in the skyline is a 47 second lap. that was the second lap i did on qualifying slicks. only did 2 laps to get that, and it was with all the settings i used on the sports tyres.
then i cracked out the polyphony and did a 44 second lap. then had a look at the records and my best is a low 42. going to try to get into the 41's... then the 40's, then the 39's.
  • Replies 102
yeah that last corner is a killer when you're on a good lap - ahead of the ghost car and only 1 coner to go... My normal mistake when trying too hard is to leave the braking slightly too late and just run off the outside of the turn...
umm, I've done a 52.693 :rolleyes:
Edited by hrd-hr30
well i see your 52.693 and raise you with a 52.529. then i use my special ability and get a 52.174. i'm on fire tonight. the 52.174 seem like a slow lap cause i wasn't all over the place. did finish it on the grass though. got on the gas a bit early out of the last corner.
don't think i'll be able to get any better than that, but going to try!!
and i did beat it!!! a 52.033, followed up straight away by a 51.474.
in a r34 gtr (its bayside blue, maybe if it was red i could go faster) on soft street tyres, no nos, but with a wing.
turns out i had been hitting the limiter in 6th down the back straight. i had been too busy looking for the braking marker that i hadn't noticed.
i have just been on fire all night. i had done heaps of 52.8 and 52.9's. over the past few days i have probably done over 300 laps. tonight alone i have done at least 80 laps. i think that is all i can do. i really don't tink i can go any faster on street tyres with that car.
Edited by mad082
also in turn 3, brake earlier so you accelerate through the corner rather than out of it. you should come out of it in the middle of the road, not out on the ripple strip. this gives you a better run into turn 4 and you don't slide so much. i use the fast in, fast out technique for cornering. i don't take nice even bends. i turn them into double apex turns. you end up with higher tops speeds at the end of the straights.
also if i don't get a good run out of the last corner, i don't bother trying for the next lap. i'll putt around and focus on getting the best run out of the last corner so that i cross the start line as fast as posible.
;) that's too good for me! I can't see me going much faster. I did a 52.625 last night before going out, and run pretty consistently in the high 52s now unless I have an off, but I can't see myself getting anywhere near those times. then again, most laps I ever do before I've had enough is around 10-15. I don't have your powers of concentration - or patience?
mind posting your suspension, gearing and LSD settings? I wouldn't mind having a run with your setup to see if I can go faster.
Edited by hrd-hr30
will do tonight.
i know a few off the top of my head. the lsd is stock, downforce is set to max, gear ratios are stock, but the one that shortens or lengthens them is set to about 9, suspension is the stock racing suspension setup, no brake controller, traction contol set to 1, understeer set to 7, oversteer set to 3. this makes you go into the corner sideways, then you just gently get on the gas and drive out of the corner well.
also think about how your line out of that corner affects the next corner. this is only really important for corners 2-3 and 3-4.
that 51 second lap was a freak lap. i don't think i could do it again. i could do the low 52's again, but not the 51.
i also found switching off the ghost helps a little, simply for the fact that if you get a slightly worse run out of one corner it blocks your vision of the braking spots.
will do tonight.
I tried that last night - I was way slower than my setup with diffs and suspension tuned/setup for the car. The traction control (or one of them) interferes too much with getting power down and it can't match my 52.625 ghost car out of corners no matter what I try. It doesn't seem to brake as well either - seems like the understeer control interferes with braking as you turn into a corner, which is a real problem for the final RH sweeper. I have to brake a fair bit earlier than my other setup just to stay on the road there. That 51.474 (and even the 52.0 and 52.1) times you set are very impresssive. do you do any online racing with one of the granturismo boards? I used to race online with granturismobynumbers - won a few too.
no. maybe i should.
as for the traction control, i found that with it off i was getting too much sideways sliding accelerating out of corners. will have another go without it tonight if the missus doesn't get up me.
Gave the game another crack tonight after a long absence -
Went from:
- 52.285
- to 52.242
- to 52.097
- then 51.889
On street tyres (no driving aids except traction control set to 2) & Wing.
Consistantly doing low 52's - hopefully i can break that record of yours soon, mad082 :w00t:
Steve.
also the other regulation is that it must be a road car, not race car. and it must be japanese.
No probs (my 45.999 was done with the r34 road car: R34 M-Spec Nur '02, but with racing soft tyres)....gave it another crack last night with the same car, just street soft tyres, wing, no NOS and some traciton control aid -
Best result: 51.468 :(
Should be able to squeeze a bit more off that tonight :(
Cheers,
Steve.
you will have to post up you suspension settings, and other mods.
OK, no problems - These are my only modifications to the road car (R34 GT-R M-spec Nur '02):
-Power: 874kw
-Tyre Type: Sports
F: sports/soft
R: sports/soft
-Turbine Kit: Original
-Brakes: Racing Brakes
-Racing Large Intercooler
-Driving Aids: TCS Controller = 2, the rest are 0
-Full cust. gearbox: auto settings set to 9. No other ratio changes
-SUSPENSION SETTINGS: Original Suspension
spring rate: F 11.0 R 13.0
ride height: F 72 R 72
damper: F 7 R 8
damper B: F - R -
damper R: F - R -
camber angle: F 5.0 R 3.0
toe: F 0 R 0
stabiliser: F 4 R 4
-WING:
downforce: F 30 R 28
These settings work well with my driving style - See how it goes for you.
    • +27605538865 Powerful Lost love spells caster by Mama to work in 24hrs with Strong magic and Psychic Reading Skills. Do you miss your lover and want him /her to come back to you? Do you want your ex to be in a relationship with you again? If you miss your partner/soulmate and cannot think of living this life without them, then perform this fast spell will help you make your lover come back to you. Imagine a love spell that could bring back your Ex, return a lost lover, or fix a broken relationship. The love spells were created to restore the romance and strength of deep love while erasing the heartache and pain of the past. By restoring these emotions with a clean foundation, my witchcraft rituals offer hope to those who fear resentment and deep anger from a lost partner. specializing in lost Love Spells, Marriage Spells, Protection Spells, Spiritual Healing, Fortune Teller Many people still question whether love spells work or not, permanent or effective? This can be based from past experiences where they tried some spell casters but not fully satisfied with their results or the love spells worked for just a short period and sometimes even never saw any results. To avoid such situations you have to be careful with spell casters you approach, some are limited with certain Spiritual powers to cast good love spells to help people in their relationships Customized Love Spells This love spell is customized and suitable for bringing the one you love to you. If you are not with the one you love for any reason, we can cast this love spell to shock and manipulate the one you love into coming to you. This spell unites lovers, which includes reuniting lovers.+27605538865 Mama Naledi
    • +27737053600 Revenge spells and Death spells to punish someone until you are fully avenged By Mama Shamie Revenge spells to teach someone a lesson they will never forget using voodoo revenge spells. My spells of revenge will inflict serious harm on your enemies, so do not use my revenge spells unless you are sure. Revenge spells for cheaters & your enemies. Revenge spells and curses to help you get the ultimate revenge. Voodoo revenge spells for cheaters, ex lovers, your enemies & people who want to harm you. Give life for life, eye for eye, tooth for tooth, hand for hand, foot for foot & to punish your enemies with revenge curses & spells for revenge. If someone has truly wronged you and you want to get back on them with the ultimate revenge spell, then try this witchcraft death revenge spells. The most precious asset we have is life so the death revenge spell is by far the most powerful revenge spell in the world as it will lead to the death. I only cast the death revenge spell when you have given me all the proof that the person you want to cast upon deserves death as punishment. Spells for revenge to cause your enemy to have sleepless nights & frightening dreams. Banish bad dreams & nightmares if someone has cast bad dreams revenge spells. Call or Whatsapp me on *+27737053600*
    • Spell to Stop Divorce in your marriage +27605538865 Stop Separation with my Spell to stop Divorce Lost love spells caster The forces involved in this witchcraft spell can reestablish the loving bond between you and help to build a sturdy, loving relationship from which to start anew. Despite any previous hardships or issues, the spell work will reestablish the strong bonds of friendship and love upon that the wedding and relationship originated. Have faith, these rituals are very powerful and can reconnect you and your partner during a strong and harmonious relationship. If you think that your partner is considering either separation or divorce, use this magic spell to stop the forces that are calling it quits your relationship. It is very necessary that you act with haste since prolonged negative energies create difficulties for the efficiency of this spell. If your partner has already breached the subject of either separation or divorce, use the spell immediately to rekindle the love that’s the idea for your marriage or relationship. Stop a Divorce or Separation
    • Court Cases and Legal magic spells +27737053600 Win a Case Spell Mama Shamie People are accused of things they never do and others did they but need a retreat, with my Court Case Spells, you can win any kind of case whether you are guilty or not, are very effective magic spells; Court Case spells are used to solve any type of court case or legal matter problems. If you are suffering and tired and the case or any legal matter that you are going through is not ending then you may contact me for a very strong court case spells. and you overcome it. If you having problems in winning Court Case then you may try casting this spell and it will surely give you positive results. Court cases magic spells are designed to rescue you from search legal accusations in a very convincing way. Black Magic Court Case Spell ✝2️⃣7️⃣7️⃣3️⃣7️⃣0️⃣5️⃣3️⃣6️⃣0️⃣0️⃣ Black magic court case is very powerful magic spell specifically cast with black magic features to generate more magic energies to relive you off the hook from being convicted no matter whether you are guilty or not, the spell has enough power to make your case either dismissed or ruled in your favor. The power of magic can play tricks with the evidences with the aim of disappearing some of them which would have lead to your conviction; there is no limit to where the spell can end until the target is reached. +27737053600 Mama Shamie
