tried the amuse s2000 and fark that thing is quick out of the box!!! could only manager a 55.504. tired a wing on the fd but it felt worse, tried to change the suspensiong but still felt like crap. took wing off and tweaked it a bit more and managed a 54.191!!! 53 seconds here we come.
  • Replies 102
beatcha to it! I put a wing on my 738bhp '89 GTR - 53.829!
then I decided to try other GTRs to see if any can get more power.
GTR VSpec N1 '93 749bhp 54.003 with wing. haven't tried any others yet.
Also got a Honda NSX '01 with 462bhp and wing to 54.673. Not bad for the power its got. Can't seem to turbo any of the NSX's :)
IM A NERD NOW.
51.86 in the koingseggC8XS(whatever it is) how ever u spell it in forza.
does it count?
from a different game on a different platform in a non-JDM car? yeah, no worries! sounds like a fair comparison!
Mind telling me your set up's for these 2 cars to get these times?
Also got a Honda NSX '01 with 462bhp and wing to 54.673. Not bad for the power its got. Can't seem to turbo any of the NSX's :rofl:
fark that is quick for a 4wd car! i find that all the 4wd cars i drive have too much understeer to run quick times but now i stand corrected! tried the r34 v2 N1 with about 700ps or something close to that and could only manage a low 55. i think i had the suspension a little too hard for sports tyres but with 12kg spring front and rear
here you go. try them out and see how you go...
both have Sport Soft tyres of course. I won't list every part I bought because its enough typing already, just assume its done unless I specifically say it isn't. I never use NOS, and have never used the weight balance settings either - both of those feel like cheating...
Nissan Skyline GTR '89
738bhp/1215kg
just fully modify the engine (no NOS) Turbine Kit: Original
get all the driveline bits (triple clutch, race flywheel, carbon driveshaft) except:
LSD: standard (changing them on GTR makes them understeer like a dog)
AYC Controller: none
Variable Centre diff: none
Weight Reduction: Stage 3, no cage (incr rigidity), no body refresher plan
Brake Controller: none
SETTINGS:
Suspension: Original
spring rate: 6.3 7.8
ride height: 74 74
damper: 9 9
camber: 3.2 0.8
toe: -2 0
stabiliser: 3 3
Transmission: Fully Customisable
auto setting 21
2.476 1.683 1.245 0.971 0.773 final drive 4.111
Downforce: 30 32
NISSAN Skyline GTR VSpec N1 '93
749bhp/1249kg
fully mod engine with no NOS, Turbine Kit: Original
Weight Reduction: Stage 3, with cage (increase rigidity), and body refresher plan.
SETTINGS:
Suspension:Original
spring rate: 8 10
ride height: 76 76
damper: 8 8
camber: 3.2 0.8
toe: 0 0
stabiliser: 4 4
auto setting 10
3.355 2.316 1.716 1.331 1.081 0.919 final drive 4.111
Downforce: 30 28
738bhp/1215kg
SETTINGS:
ride height: 74 74
damper: 9 9
camber: 3.2 0.8
toe: -2 0
stabiliser: 3 3
auto setting 21
Downforce: 30 32
749bhp/1249kg
SETTINGS:
Suspension:Original
spring rate: 8 10
ride height: 76 76
damper: 8 8
camber: 3.2 0.8
toe: 0 0
stabiliser: 4 4
auto setting 10
Downforce: 30 28
wow you run really soft suspension. on the rx7 i run 12 and 10 spring and 10 and 9 damper. Will have to try no lsd in the gtr and see how i go. got a bit closer to the 53 last night, 54.087! anyone tried messing with the brake bias with any success?
been trying other GTR's and found a winner- R34 GTR 53.007!
A 52 should be possible but it will have to be a pretty damn good lap. not an easy car to drive though - it needs the throttle fed in progressively out of corners and how well you do that makes or breaks the lap time.
i think we have a winner!!!!
52.098!!!!!!!!!!!! on sports tyres!!!!! in a rear wheel drive car!!!!!
the gillet vertigo race car '04. mod it full up, leave all the setting stock except for the gear ratios at about 11, traction control at 3, and no NOS
and i'd can say for sure that 51's are possible with this car. i have been faster to the second corner than the ghost of that time, but f**k up the entry and run too wide, or cut to sharp and hit the ripple strip.
Edited by mad082
other people have done laps in non jap cars. and i class the vertigo in the same class as any car bought from a tuning company (not original manufacturer).
the game specifies if it is a race car in the car's title - eg "Gillet Vertigo Race Car". Its in the same class as the other race cars in the game. You won't find "race car" in the title of any of the other cars we've used.
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
