Hello all,
I replied in the Apexi PFC FAQ thread as well..
My car is running really rough, the idle is low and its unstably jumping a few rpm while on idle. Can some one help me out here please? I have set the Injectors in the PFC to 74% correction and +0.04 latency but its still no good. :)
Is there something I am missing?
I have never played around with the PFC settings before.
https://www.sau.com.au/forums/topic/132718-installed-600cc-injectors/
although not entirely the same i installed gtr replacement 550cc injectors in my rb20det. adjusted them on the powerfc and it ran ok but fuelly. idle tracked around a bit but not bad really for a 50% adjustment. a dyno tune fixed it nice.
if you can drive it to a tuner do that. i know where you're coming from on the labour thing
Unforetunately I will have to install the old injectors to be able to drive it, the idle is all over the place :)
What did you adjust in your PFC settings? All the tutorial says to do is adjust the Injetors to 74% and +0.04
  • 3 months later...
well you'll have to get it on a dyno to get it runnin right anyway (i think), so you can either reset the ECU and let it learn to idle, then take it to a tuner for a complete remap, or just take it to a tuner and let him make minor adjustments to the main maps, then maybe mess around with it to try and get it to idle.
im not completely sure on the retuning thing just for bigger injectors, but its just what i'd do
After the injectors problem I installed cam gears and after replacing everything back onto the engine it was running worse.
Took it to a tuner and got it fixed up. My problems were not with the PFC tune that I did myself initially. From what I can see from the tune, the settings are pretty much what I had when testing it. Must have been something about what I did, but I will never know....
Moral, don't do it yourself if your me :)
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
