Is there anyway to stop that auto-locking "feature"? today, i had the unfortunate result of that feature happen to me, basically my keys fell out of my pocket into the car when i reached in to get something, long story short, the car locked me out and i had to call racv to come and break into my car (took him about 2mins to break in :) ). Can that "feature" be disabled or do i just have to live with it?
Edited by RyanN
https://www.sau.com.au/forums/topic/132741-that-skyline-auto-lock-thing/
nah it doesn't have an aftermarket alarm yet, and no the car wasn't moving at the time :) It seems to lock again after a few minutes of remote unlocking, i thought it might of been a nissan security feature... but if your cars dont do it then was there an optional security system or something that this might be linked to?
after thinking about it for awhile though im considering taping a spare key to i/c piping inside the front bumper, that way i wouldnt have to, the next time this happens i wont have to worry about somehow getting home, finding the other spare key, then getting back before someone else takes it. sane idea? :)
Edited by RyanN
OK...we'll take note of tht :O
But seriously...should be a way to disable it...its a pain in the arse function...maybe post on the alarms and car audio section and wait for chris rogers to answer.
its a skyline thing as far as i know...
lol 2mins to break in... what a pro.
yeah he used a little air bag thing he pumps up near the top of door to create a small gap, then reaches in with a piece of wire to pull the lock back; it took him longer to fill out the paperwork.
OK...we'll take note of tht :)
im guessing its hard coded straight into the ecu... maybe actually installing an aftermarket alarm could override that feature.
nah it doesn't have an aftermarket alarm yet, and no the car wasn't moving at the time :D It seems to lock again after a few minutes of remote unlocking, i thought it might of been a nissan security feature... but if your cars dont do it then was there an optional security system or something that this might be linked to?
after thinking about it for awhile though im considering taping a spare key to i/c piping inside the front bumper, that way i wouldnt have to, the next time this happens i wont have to worry about somehow getting home, finding the other spare key, then getting back before someone else takes it. sane idea? :D
My R33 series II is supposed to do the same thing (according to the manual) however is doesn't.....
Not that I am complaining.....
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
