Hi i was just wondering what the advantages and disadvantages are of putting a lightened flywheel in my r33 gtst. Does it wear the clutch out quicker? Does it affect performance in a big way and in which ways?
Edited by 4AL2NV
https://www.sau.com.au/forums/topic/132749-lightened-flywheel/
From my experience, a lightened flywheel makes for easier gear changes when you're really up it but for normal street duties it's more of a pain since it can promote stalling and make it a bit harder to drive off from a standing position in traffic. ( This was on an RB20DET but it might be different on an RB25DET or larger engine and might differ depending on how light you go ).
Drag racing - use standard flywheel, reasons is it wont drop off boost during shifts (as much as a light weight one), it will hold up better than a ligthweight one i.e wont bend/warp as much/quickly
Circuit racing - Lightweight flywheel, reasons is better throttle control during cornering, revs quicker, less rotating mass on engine
Unfortunately both of these statements are false.
Dropping off boost during shifts.... No matter what flywheel its going to drop boost between gear shifts as you shut the throttle slightly. If anything a light flywheel will help get the car accelerating again as there is less flywheel inertia to overcome.
The bend/warp statement is also strange; flywheels don't bend and warp, they simply chew out.
Aftermarket items such as molly have a greater resistance to being chewed out compared to the std item.
I ran an aftermarket lightened molly flywheel on my old mild rb20det some years ago.
Personally... There were no negatives and all positives.
Off idle acceleration in low gears was noticably brisker, no increase in stallability, if anything it felt freeier accelerating from idle rpm.
Gear changes were considerably easier at high rpm
Rev's would drop quicker making it sounder crisper when coming off a hard second gear boot.
Boost felt like it snapped on just that little bit harder.
Fuel economy didn't change
No noticable change in constant cruise feel when you hit a slight incline
Simply.. the car did feel slightly quicker/brisker in the lower gears; high gears, it felt the same.
The ONLY noticable difference is the car required a few more launch rev's. It actually made the car easier to get off the line even though the car now required a higher rpm launch (4000rpm vs ~3800rpm)
Definitely worth while.
I've since gone back to a std flywheel due to different motor and upon the next clutch change I WILL be dropping in a lightened flywheel.
Hi i just wanted to know which flywheel you used as this one you had seemed to be very good. Thank you.
I sorta hate my lightened flywheel a bit because take off on the street are annoying. My girlfriend always complains about it and i don't wanna ride the clutch a bit to make it smoother because the os giken twins hate that alot.
I think this is the one now in my car :D yours wasn't really that 'light' 7kg as opposed to 9kg I weighed it in at :) There would be a fair difference between a 7kg one and the more expensive 4.5kg ones I would say.
So then how do you explain the fact that the bresciani wrx couldnt run the times it could with a lightened flywheel that it did when they swapped to a standard one?
What i said above is what i have been told by a certain clutch builder, and im pretty sure you can guess who that is :D
What i said above is what i have been told by a certain clutch builder, and im pretty sure you can guess who that is :)
Since when are we talking about WRX's. They are well known for being cops off idle when running a lightened flywheel, RB's are not. :D
I remember I weighed it in as I believe 6-6.5kg's without clutch. But either way, go too light and you loose go nicely weighted and there's gains.
This is the one I bought.
http://www.horsepowerinabox.com/HPIAB2/category16_1.htm
Right down the bottom, the pic does look a little different as it now runs holes in the center but none the less its essentially the same.
I personally don't think I would feel comfortable running anything lighter than 5.5kg's.
WERD :(
but...
circut use use a light one. better rev up when going up and down gears.
drags use a stock weight one. it gives more torque and better harmonics control. (ie.. dont bust that oil pump)
both statments are from my knowedge commonly accepted as a general rule of thumb. and if you dont agree cool. its your motor not mine lol
Reducing inertia (lightened flywheel) improves lower gear acceleration. How can this not be a benefit for street use?
The negatives..
Decreased stored kinetic energy thats used when launching. As a result you may need a few more hundred rpm on board when popping that clutch. Possibly a problem for 4wd's, not likely in rwd's.
And as you say the flywheel is also there to absorb firing pulses, reduce vibration harmonics, and torsional twist. Reducing this mass can reduce reliability and how smooth the engine feels.
I'm all for a slightly lighter stronger molly flywheel that I HAVE noticed a seat of the pants improvement with the gutless rb20 in the lower gears. If I ran a 4.5kg flywheel it may have been a different story. My little old rb20 covered around ~110,000km's with a lightened flywheel giving a total of 178,000km's total. The motor was still in excellent condition when it came out.
Too light yes its not good; slightly lighter I've noticed gains with no reliability issues.
I am currently running a ceramic puk clutch on the stock flywheel. Ceramic puk clutch + std flywheel is not a good combination.
The std flywheel material is too soft and chews out too quickly.
I'll have no issues dropping a few kg's from the weight of a stock flywheel for a stronger molly item. The last motor held together perfectly fine and was often reved in the lower gears to ~7300rpm.
    • I had absolutely no symptoms whatsoever that anything was wrong.... I'm very happy it was all spotto'd and re-bled and re-torqued and aligned though. Will be picking it up tomorrow and undoubtedly be like "Oh, that clunk is gone" "Oh, the car really wants to drive straight" "Oh, that pedal feels better" "Oh, it feels like I've gained 25hp" "Oh, the handbrake works now" It should have been a sign that the new Project Mu shoes had 3mm of pad depth on them out of the box, and the OEM ones from 25 years ago that we took out also had 3mm of pad depth, implying the issue was not, and never was the shoes, but we put that down to it not being adjusted correctly. It wasn't, but it wasn't even adjustable at all given one side was boned and the T Junction of the cables was on a 45 degree angle, the non-working side being the one on the massive angle. Obviously when I had adjusted it and reset it and re-tensioned it I had either got it stuck or something along those lines. Oh well. Live and learn and absolutely could have been catastrophically worse so I'm rationalizing it as a win, kinda. I also got the chance to measure the distance between rear rim and the suspension arm/shocks and found a 30mm rubber block only just doesn't fit there. Which is great to know before ordering wheels, when I assumed 30mm was easy. The man with the Porsche adapters has rims that use 23.9mm of that space, so it's safe to assume I have between 23.9 and 29.9mm of space there to play with on the inside. The wheels looked pretty stupidly pokey with the 20mm spacers on the rear, only for me to find that the studs come out another 12mm and the wheel doesn't actually sit flush with the hub because you're supposed to cut your original studs. The wheels do have cutouts that kinda accomodate it, but not fully. So my 20mm spacer was anywhere between 25mm and 35mm. ~25mm and send it will determine on where the wheels sit with the spacers on. When I put the pads in for the track day I will mess around with spacers (with wheels that do not clear studs properly when mounted to spacers) and do more math, for the last time, for the 7th time.
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
