It all depends on what else is done to the car, and what you use the car for.
Stored flywheel inertia and some clutch slip is the only way to get ANY manual transmission car moving from complete standstill without stalling. But so very much depends on available engine torque, vehicle weight, and overall gear reduction in first gear.
Once you are moving, the flywheel is nothing but extra weight and extra inertia you no longer need. A circuit race car is not normally doing constant starts, so a very light flywheel is usually an advantage.
A drag race car with excellent traction will launch harder with a heavy flywheel, but that same flywheel may slow down the rate of acceleration once it has launched.
Turbo engines are special, because they usually have minimal torque when off boost, particularly when starting off. If your engine is laggy and has a fairly high boost threshold, a light flywheel is going to make starting off even more difficult than it already is.
If you drive the car every day in heavy traffic, a very light flyweel is quite likely going to be a real pain in the arse, especially with a highly modified turbo engine.
In flat places like Melbourne, it will not be quite so bad as in hilly Sydney. Starting off facing up hills needs plenty of flywheel.
Its 'almost' a little contradictory but not quite. The initial take off may require a few more rev's but once past this the car will (as I noticed) rev up quicker and feel as if it actually has a little more off boost acceleration. I didn't notice the more rev's requirement from a standing start under normal driving conditions, it was only when launching the car.
As I think I said earlier I found the gutless rb20 easier to launch with the lightened flywheel, it did require more rev's other wise it would bog but launching at the correct rpm it felt as if it was easier to control any wheel spin that occured and it simply got off the line cleaner.
An R32 GTS4.... I would most definitely stick with the stock flywheel, they require an almost redline launch not to prevent bog, in this circumstance a lightened flywheel would cause launching problems as a result possibly slower 0-100 and 1/4 times. As we all know the faster we can get up to speed earlier the quicker our 1/4 will be. The old Auto VLT's are a prime example of this running mid 10's with only ~300rwkw.
I'm with Cubes on this one, and is the exact reason I'm going for a lightened flywheel when I change my clutch in the next few months hopefully. The RB20 is a dog for me driving into/out of the city every morning, stop start conditions, and off boost acceleration is very poor.
Also of note, what I picked up a few weeks back. The weight of a flywheel is not as important as the distance that weight is from the centre. I believe it is a radius ® squared relationship. Hence a 10kg flywheel with a large part of it's weight on the extremities will be a lot harder to turn than a 10kg flywheel with most of its weight near the centre. This is why you see standard flywheels being lightened with holes/removal of steel as near the extremities as you can get. This has big benefits even though it may only lighten the flywheel by a few kg's.
Fixxxer :D
I have a 4.5kg flywheel in my car.
Positives:
- engine revs easier
- revs drop really quickly
- less engine braking
Negatives:
- revs drop quickly between gear changes
- need revs to get the car off the line
- meh..
I like it.
  • 4 weeks later...
Slightly cheaper price for what looks like the same item here;
http://www.tweakit.net/shop/index.php?cPath=326_367_374
Does anyone know the weight of the RB25DET standard flywheel?
Also Aluminium @ 5.0kg for around $520 or Chrome-Moly @ 5.5kg for $100 less???
    • Thanks mate for that reply. Very helpful.    it’s a 2022 400R so would most likely lose those features as you say.     I did a quick compare of a rv37 nav and heading for sale in Japan to q50 model. I’ll pop pics below. Seems  Japan spec head into top, nav unit second below it   below pic Q50 aud delivered     differences seem to be Aus delivered has a different plug top left hand side of head unit- not sure what and where it goes.   and nav unit Japanese tv37 had an extra plug put    Again I’m really not sure what each of these differences mean!       the actual plugs on a v37 and q50 screens look identical on both screens… pics below for comparing. (One screen was is a us delivered one) but should be same gps signals etc as Australia.    If it were as simple as swapping a nav unit from q50 aud delivered im interested -just want to figure out what the missing plug is for before spending big $ on a second hand part for it to not work, and I guess with the head unit, if the band expander does the job (I got a 20mHz so should get the range I’m after) so should narrow my issue down to nav unit only.  I’d love to know what the extra cable on rv37 does and if I elongate that part what it’ll do to the setup,    and also, if I can figure out what that head unit plug difference is, what does that cable do and where does it got can it be altered or re-plugged?! Excuse my ignorance what is ACP/AA, what does that stand for?   Thanks for the info re tyre sensors, helpful and great to know.  I was reading the online manual off Japan website and it seemed to make it sound more confusing than it is  I guess a rim replacement would require the sensors to be moved to a new rim to carry that option over?!     Thanks for the info regarding diagnostic mode. I appreciate your help mate. Trying to brainstorm here to find a solution to get as much gadgets as I can working! I plan to get my local Nissan tech to have a look too who used to be at an Infiniti dealer back in the day to see if any thing they have or idea can find a soliton. But hoping anyone here has gone down the same route to make life easier!!   i guess identifying the cable/plug differences and what they do would be a great way of finding out if the units are transferable    thanks again
    • No idea about the remote start part. If the V37 nav is anything like other Nissan JDM vehicles, you can't get the factory Japanese nav working in australia, a card from a different car almost certainly won't work, those cards are usually matched to the serial number of the DCU.  You could be possibly swap out the components from a AuDM Q50 to get it working, but if this is a new model (2021+) 400R, then you will lose the newer features like ACP/AA.  That said, if you have ACP/AA, just use google maps.. I assume a band expander would be required to get the local radio stations, but don't forget the Japanese FM band is narrower than ours, so you still might not be able to receive all Australian stations. I can't see any reason the tyre pressure sensors won't work here, there is the sensor unit inside the rim and the receiver nearby in the wheel well.  I have never had to change the batteries on my 2015 Q50, so I assume they last quite a while.  A straight battery change shouldn't need them to be re-registered as they are the same unit, that should only be required if you replace a sensor with a new one.   Word of warning, if you ever go into the 'secret' diagnostics mode on the main screen, DO NOT EVER do a 'reset' in this menu, it will erase all of your model specific data in the DCU and you will need a trip to a dealer to re-program it all, which would be particularly painful being an import.  This applies to the AuDM Q50 too.
    • There is a known issue with the mix door motor on the Q50 which causes these symptoms, not sure if it is common on the Y51 though.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
