Hi guys i have been looking at a gtrs for like the past few months
as an upcoming uprade ,but i have seen the apexi AX TURBINE AX53B70 Kit
item code:705-N030, and i carn find any info about it ,have looked but to no
avail, is anyone running it, and what is efficent power range.
have found a few pics , but no real good info , like comp maps etc
Cheers all
any help will be great :P
Edited by gtstcoupe
https://www.sau.com.au/forums/topic/132776-apexi-turbo-kits-for-r33/
apexi dont release compressor maps, like hks.
theres probably not a great deal of information as not many people use them. people prefer to use a proven and well used combination, as you can see what results youll get and it takes out the guess work.
the rb25 turbo upgrade thread covers most of the common turbo's so you would be mad to go out on a limb and choose some not tried turbo and be disappointed with the results
Just google "apexi AX53B70 turbo" plenty of info out there
from what I understand, better response then a HKS 2535 and more allround power too.
if I had the cash to buy a brand name turbo - my money would be on this turbo
from my experiences with owning this turbo, but on a rb20 and research into them on a rb25
they are nearly as responsive as a hks 2530 and around the same power as a gtrs
ultimate low mount for this kind of engine in my opinion
seen one make 238rwkw on 10psi with a nearly perfect torque curve
that is good power 10psi , yeah i woundlnt mind going something different and it is a more complete kit with all gaskets etc, but the gt-rs may come with then but they may come with them, looking to also find a power figure ,but i s kinda hard to find for the 25det heaps for sr20 etc
I've got one of these running on my car..
Mine is putting out 225kw at 14psi, but i'm running a very safe tune (rich) and i've got some other issues that need sorting out (need hiflow cat and cams). These turbos have AWESOME response. Everyone that has tuned/driven my car is amazed by how meaty the mid-range is. Power capability of the turbo top out at about 270kw I think. There are a number of guys using the same turbo on SAU actually.
Bunta - has just had one installed - 240kw untuned
Phat6 - http://www.skylinesaustralia.com/forums/in...howtopic=120898 - Just sold his GTS-T with this turbo which pulled 240kw.
This thread has some more info: http://www.skylinesaustralia.com/forums/in...&hl=AX53B70
I'd definitely recommend it!
Dyno Graph:
yeah i've heard that it runs out of huff around the 260 mark, but also heard that some people have managed more. with the way that dynos can be incorrectly calibrated though it'd be easy to overshoot the 260 mark :)
Nah Bunta was getting 245kw on 1.1 bar (16psi)...
Quote:
Bunta Wrote:
"Finally got the results back from tuner...245rwkw VERY conservative tune and 1.1bar of boost not sure of the torque figure as I have not actually seen the graph yet, The tuner wants me to run it on this setting for a month or so to make sure everything is coping then he is confident that a bit more boost and a more agressive tune will get another 20rwkw roughly! So there you have it! Somthing to compare too at last!"
hey i have this turbo,
but am yet to install.... very interested to see as 2 what people say about it... i decided myself to go out on a limb to see what they are like as there made by apexi i figured they would have to be preety good...
all help apreciated here...
One of the lads in the sa section suggested that he was pulling 300rwkw with one of these, a whole lot of mods tho (maybe including engine rebuild) I believe.
Fact is, Id love one of these turbos, but I could never afford a new one, and after months of searching for a 2nd hand one I sorta gave up. Im going to use Slides turbo for around 3 to 4 yrs, and then relook for one of these apexi turbos for my awd stagea. ;)
thanks Primordial.
Found this page
http://www.apexera.co.jp/carlife/pro_apexi.../ax53b6070.html (use bablefish to translate www.altavista.com)
I worked out from the pdf that it would cost about $2,588 before delivery.
Anyone who of any other places this turbo can be purchased from?
cheers
Edited by Munna1
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
