Hey all,
Was having a good look at the rear wings off of a Holden V8 supercar over the weekend and wouldn't mind trying to get my hands on one for my car. Does anyone here have any connections to sourcing one of these secondhand/not using anymore/last years wing etc??
Thanks
Dane
https://www.sau.com.au/forums/topic/132822-v8-supercar-rear-wing/
  • 6 months later...
my advice is don't listen to troys advice.
get the biggest, nastiest wing you can. sadly my JGTC wing is gone now. finding a home on a silvia.
I regret selling my big nasty one now as it would not look too out of place on my car anymore with the new rims, and cage, and seat, and winglets etc. oh well.
just volunteer as a marshall at a race like adelaide or indy. there is bound to be plenty of carnage on a street course. then when one gets knocked off, run out, grab it, then keep on running!!
Holden
Yeah, functionality is the reason I want a supercar wing, at least I will know it will do something. The type X wing I'm not sure about...
Functional. They are a pretty big wing, and they run in combination with undertrays on V8 Supercars. Sure give one a go. But i think you will find Nissan didn enough homework on teh Type X wong that you will be ok.
All gut, no real science, but i know of two cars that are slowers around Sandown and PI with aftermarket wings
That wing would have been good Richard, but I figured Duncan had got it anyways. I like this biggest, nastiest wing I can find idea, hence the supercars :w00t: At least they're suitably wide enough for my car, and cheaper than a big f**koff C-west carbon job.
Troy, I'm planning on running an undertray as well. I'm also aware of it possibly making me slower, so I was going to try just an undertray to start with to minimise the drag of a big wing, and if I'm not happy then invest in a wing. I feel that I need something on there, and ideally it would be some sort of lip/ducktail, but I'm worried that something like that may throw my aero out of whack.
there is a JacK daniels V8 SC look a like at sports bar atm in crown complete with rear wing. I say down a few beers to enlarge the balls and shrink the brain then get in there with your tool kit. :blush:
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
    • Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
    • Nothing photo worthy since last update, lots of little plumbing bits for the AAC/Cold start valves, and unfortunately I still need another couple of parts for the brake booster line and the AAC into the plenum. Otherwise it all looks good to start up engine wise, onto checking the electrics/interior
