Didnt' one of us have an ex K-mart racing wing? I think it was Garreth he is, maybe ask him!
Yeah, Gareth has one. I know where he got it from, and there's none available. I put in an offer on the same wing... he beat me by about $10 :wave:
Richard: That's not a bad idea... It may be worth the severe beating I may cop! I was thinking more the 'rip and run' though haha :pirate:
hahaha I'll consider it Troy :dry:
The toughness of these standard engines are surprising me, and I've always been a big advocate of the strength of these engines... I just comp tested 162, 159, 160, 160 on my stock engine
Like this Troy??
  • 1 month later...
dean, gt wings are aid to make under diffuser work, you'll need a serious of both to make them work 100%.
we just wind tunnel tested under diffuser and wing, we will be releasing them in couple of months time.
we had all the setting now to make them. but they won't come cheap bro, wing and diffuser package around $2k.
if you want to see the car in action, look at the super sedan series, we tested on Kerrick sponsored swedish prestige saab this coming 25or 26th may at qld.
real racing is very serious matter, you will need a new front bar to aid the rear dean, your front is nono for downforce.
we also tested front diffuser angle too. :O
the setting are classified until product released.
well i have a wind tunnel at home troy. it's 1/10th scale though and powered by twin black and decker desk fans. as long as you can make a model of your spoiler small enough (no bigger than about 15cm wide) then I'm happy to test it for you. for the smoke trail I use a bong or sometimes a crack pipe if I'm out of pot. can only test for about 10 mins and then I can't smoke any more and the results become a bit wild.
we also tested front diffuser angle too. :P
Hey Freddy, sounds interesting mate, I'll give you a buzz about it and come down for a chat to see the designs :)
Have you designed other front bars? I really would like to keep mine, but we can discuss options. I know the Kerrick car, but I'll take a closer look at it.
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
    • Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
    • Nothing photo worthy since last update, lots of little plumbing bits for the AAC/Cold start valves, and unfortunately I still need another couple of parts for the brake booster line and the AAC into the plenum. Otherwise it all looks good to start up engine wise, onto checking the electrics/interior
    • Good news mate, plenty of spares available 5:40
