No it's not the title to a chinese who done it.
I have a strange little problem with a mystery 'knock'.
I can give it a full throttle take off from standing and 1st gear all the way to 7000rpm is without a rattle. Into second and third there is just a brief knock at 5000rpm each gear.
I was wondering if this is the sign of a dicky fuel pump or perhaps something else?
https://www.sau.com.au/forums/topic/13289-knock-and-ping-mystery/
You probably know this, but remember that the higher the gear the more load is on the engine and therefore more likely to ping.
You might have to pull 1 or 2 degrees of timing off of her.
Or doesn't it happen in 4th and 5th??
I suppose to find out if it does ping in 4th or 5th you'd have to be doing mach 3 or something :rolleyes:
thanks for the ideas so far.
No it's not a timing issue, the knock is 'before' full power and timing can be pulled back 10 degrees and it will still occur at the same magnitude. Obviously I take off timing if I can 'hear' a ping at any time but, quite often this is just a very strong 'knock'
I had a feeling it might be a fuel supply issue.
This might be a long shot - but it could be the harmonic's of the motor at those RPM/Load. Sort of extra 'noise' that the knock sensors think it's knock...
Any idea when your peak torque is?? Could be doing it on your peak torque too??
Strange stuff though - like said before, might be time for a test and tune on a dyno..
I suppose to find out if it does ping in 4th or 5th you'd have to be doing mach 3 or something :P
Yeah i agree whack some timing out to be sure...do your octane.....do it on a cold night...only one at a time and u should figure it out easy enough.
Dont forget rb25s are prone to pinging with their high comp ratio...
If the fuel pump was dying u would ping all the way and your engine would last 2 minutes.
ur saying its only faint? turn your stereo up :D
rev,
I have the exact same problem, i only have an exhaust, filter and BOV.
I put on a atomic bleed valve to upped the boost to find that it got worse (obveously), then wound it down to find that it was still there. i have have plugs changed, platniums make no diff, and changed the gaps with no luck. my only options left are the Air flow meter (could be that) or the fuel system (like a coil pack or the like). waiting until i get motec before i look further into it. its just too much hassle looking for this thing blind.
Although run BP ultimate, this made it less.
Good luck and let me know what you find out.
never flashes.... i dont think that its a pinging however, it sounds more like a popping from the exhaust with a engine retard at the same time. the car exhaust rumbles off load and backfires between low speed up changes.
havent checked timing though. ive had it a slakos whoes done a full check on the thing and sees nothing wrong with what could be obveous, went to cred and they just changed to platnuims, worked fine until i got home... then you guessed it... back again.
pinging will usually happen under full load, full throttle
if u back throttle off...its not ping....
maybe your too far retarded.(timing :P)
usually advancing to 15 deg and over makes the pop pop go away unless u have a straight thru with only one muffler so the engine doesnt have alot of backpressure
anyway.....
thanks macka,
the sad thing is that i cant even get the thing up to full boost at the moment as the clutch is on the way out, it will slip shortly after 5krpm.
geting it replaced next week, and i will get the guys to have a look at the timing at the same time.
i do have a 90mm straight through exhaust to a tip muff. i also have a rx7 racing cat on the thing... it sounds blooody mean i tell you. would think that it would be a issue though...
I have run octane shmooster and it persists. Backed the timing off.
I've got some BCPR7ES plugs in now and still it persists (better power delivery up top tho' with a nice 1.0mm gap.
I'm thinking its a fuel thing, might have to try a big wack of extra fuel just before 5000rpm. The other thing it could be is cooling system (say it aint so!).
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
