Looking for a 3 - 3.5" cat back system for my 34.
Must be stainless or mild steel.
Preferbly Nismo (Like factory Cat back), If not let me know what you have.
Must have oval muffler, no cannons please.
Thanks.
https://www.sau.com.au/forums/topic/132899-cat-back-exhaust-system-for-r34/
Just to let you know, Nismo factory cat back for the 34 is 2 1/2"-2 3/4" at most - it's mild steel to the muffler, and the muffler itself is stainless.
If it is indeed 2 and 3/4 thats cool.
Thanks howie.
hey bro, im gettin a full exhaust done next week so if you want the stock ill sell it to ya $300 for the lot or $150 for cat back
im in brissy tho and postin it will be heaps so up to you if u wanna pay postage
