Hey guys
well i've been driving the R33 for a week and a bit now and all seems pretty sweet. There are a few things though that I'm looking into. I'm experiencing a vibration at exactly 100km/h and above (worse at 100ks)
It feels like the shudder is coming through the pedals, however its more through the suspension and geometry of the car. Its not brake or steering shudder as I know what they feel like.
The suspension is VERY hard and i'll be replacing it with new coilovers shortly, however this sort of feels like its more in the pivoting sections of the suspension geometry, morel iek a tie rod or something?
Any ideas on where to look?
Thanks guys,
matt
https://www.sau.com.au/forums/topic/132938-high-speed-vibration/
I know exactly what it is, my mums car use to do that at exactly a hundred aswell u need new tires, we changed that on my mums car and problem went away, for example she had really bad rear tires but ok front tires, we had to change them all. Also get a wheel alignemet it wont kill u but it will save years on your tyres and they only about 40 bucks.
Thanks guys,
matt
Yeh well i would look at the actual tie rods and see if there is any play in them. Might be a good place to start. Jack up the front end and try and wobble the wheel without actually turning or moving it, see if it moves in its place.
We had the same issue straight after we got the 33. It ended up being a tyre that was out of round. It had a large bump in it, kinda looked like a massive goiter! Changed that, and all was sweet!
You can rule out tie rod end if it's not coming through the steering. My money is on the tyre cept a delamination like Terry and Anna experienced is more likely to be felt at lower speeds eg. 40-60. I would just take it to someone who knows what they are looking at and ask for their opinion. If they are nice enough they won't charge you for that.
check the weights on your rims, see if they are properly weighted. my car had a shudder at 100km/h aswell, i took it back got the front wheels rebalanced and he said they were out and one of the weights were missing off the front rim.
also see if any of the rims have a slight buckle in them.
Edited by 85URK
The Tyres Would be my 1st call, what tyres are on the car.
Some times if you have a cheaper tyrer fitted you end up getting what u pay for, saying that I have seen Goodyear Eagle F1's Egg. Egging of a tyre is not uncommon, seen it a lot, I would look at shocks, some times when the shocks have gone soft it can lead to the tyre getting a egg in it, excess bounce etc etc just worth a check...
Hope that helps a little more Matt
Id be down to a tyre shop...
There they would look at many of the above things and they can do them all in the same place...
1. Wheel alignment
2. Wheel weights and balance is correct
3. Tyre is out of round or de laminating
All three are easilly fixed and can all be done at your local.
My bet is like everyones, alignment and balance, usually the case if vibrations are felt over 100kmph as seems to be the most common problem, aswell as when were the wheels balanced and aligned, usual thing is every 5000 to 10000 kms they should be done
picked the car up from the tyre place, he said the rear wheels were f**ked, rear left was out by 7 degrees, he fixed the alignment then balanced the rims, and again said the rims were all over the place, had to add 50 grams on one and 60 grams on the other. I've had all that fixed and it runs awesome now. He did say the rear tires were shit and there was a lot of 'run' in the walls of the tire, if there is more vibrations then that is why. So i'll be putting new rubber on the rears at least. Any thoughts on good tires these days? I'm running Falken ST155s on my Z and i love them.
Thanks for all you rreplies too by the way - other forums just don't bother to reply on simple questions like these - thanks
my chopped/heated springs used to do that something fierce
bought the car like that
all gone since coilovers put in
other symptoms of wrecked suspension
used to shred the inside edge of tyres in 5000ks
rest of the fronts would be full tread, inside 3/4cm, through to belts
no amount of wheel balancing/aligning could save them
Edited by Spook's_Skyline
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
