hey guys
well i've been driving the R33 for a week and a bit now and all seems pretty sweet. There are a few things though that I'm looking into. I'm experiencing a vibration at exactly 100km/h and above (worse at 100ks)
It feels like the shudder is coming through the pedals, however its more through the suspension and geometry of the car. Its not brake or steering shudder as I know what they feel like.
The suspension is VERY hard and i'll be replacing it with new coilovers shortly, however this sort of feels like its more in the pivoting sections of the suspension geometry, morel iek a tie rod or something?
Any ideas on where to look?
Thanks guys,
matt
https://www.sau.com.au/forums/topic/132942-high-speed-vibrations/
good thinking, he said the wheels were done when i bought it but they came off a different car so I suspect they weren't properly done, i'll have a wheel alignment and balance done just in case. the one thing i have never expereinced is imbalanced wheels since i've always had mine done so that may be it.
ye wheel balance definately, best two on front. and if they are new wheels(new to you), then get the place to check they dont have any damage, sometime you can balance the wheel out perfectly but if the rim is buckled its still no use.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
