Anyone know a place in Sydney that will repair coilovers ??
Don't know what brand they are - but they look the goods and are nice and stiff !
One strut has a small bend in it - springs etc are good - so rebuilding would be good over replacement.
Anyone know a place that can do this ?
CHeers,
https://www.sau.com.au/forums/topic/132967-coilovers-rebuild-reco-where/
CHeers,
Hey B-man :O
try www.shockreco.com.au they just did mine for the gloria. I haven't tested them as i sold the car and the shocks went with the car un installed :mad:
cost quite a lot.
150 a corner for basic
300 a corner if shafts need hard chroming.
hope that helps!
Hey B-man :rofl:
try www.shockreco.com.au they just did mine for the gloria. I haven't tested them as i sold the car and the shocks went with the car un installed :)
cost quite a lot.
hope that helps!
I had them, rebuilt twice within 18months...
BTW if you have a bent shaft you will need a new shock regardless as they cant rebuild one corner and not the other when you have a new shock there is a minium of 2 new shocks anyway.
Just buy brand new shocks. The bilsteins are the best bang for buck.
TRUST ME. It WILL save you money. Learn from my mistakes.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
