  • Replies 40
I was taking the piss out of Porsches... glorified VW beetles :)
-> beetle pre-dates the 911
beetle - mid 1930s
911 - 1963ish?
Yeah but thats the prototypes yeah? You had the 356 porsches which were production. Im going to have to double check now!
man thatd be some snappy throttle response - no exactly a long inlet tract. Super responsive, with the filter right on the compressor. would spool up sharpish, hey. What a weapon of a car.
But... friken TEXAS plates? YEEEEHAAAWWWW i gots me a ROCKET car, momma!!! Look maw, no hands!!!
Occasionally the Yanks suprise me and come up with some SERIOUS motorsport vehicles. There was a AWESOME WRX 2 door that someone had built from the ground up(...LTS Jayce scrabbling to find the link...)that was a pure weapon,this Porka is a good run at the 'serious' tag,plus a few well thought out mudderboikes. Mostly,I'm left at the toilet bowl,awaiting the next bout of vomitting as they produce some riced out,2F2F or boat-with-big-horsepower-but-can't-turn-or-stop P.O.S. ... So,the Porsche gets my thumbs up!
The yanks build some really nice cars, aswell as nice parts to go in them, just that there are simply so many examples over there the majority of 'ricers' that we see are bound to be shlt.
I've seen a lot of nice euro's come out of the US.
there's lots of fabricators in the US that do some very good quality work. for example see the thread about "ATTESA trim levels" that I posted some pics of an R32 GTR drivetrain graft onto a silvia in.
Unfortunately these guys are eclipsed by over sensationalised and better marketed builders/fabricators... and as a result no one other than their local customer base gets to appreciate their work.
  • 1 month later...
saw this a while ago, heres the guys forum link, theres links in the first page to the build up:
http://forums.pelicanparts.com/showthread....highlight=drove
pretty much all the engine mods are custom lol. The silver tanks are intake plenums which sit above individual throttles. Random things like complete custom made loom and piping and etc.
That thing is so full of awesomes.
Edited by GorGasm
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
