Im at the point where i want to upgrade my turbo and considering the success had with the gcg highflow turbo thats the way i want to go. Ive read the threads on rb25 turbo upgrade but just want to ask a few questions.
Basically what other mods do i need to do to get the full potential of the turbo?
So far i have:
Pod Filter
Turbo Back Exhaust
Blitz Dual SBC Spec S
Power FC
+ the usual suspension, brakes, clutch mods that have been done.
From what ive seen this turbo is good for 250rwkw to 270rwkw?So i just want to get the right parts for this power output..
I plan on getting:
Hybrid FMIC (600x300x76)
Bosch 040 Fuel Pump
Things im not sure about are:
Injectors, what brand, size, etc?
Z32 AFM is it needed?
Thats pretty much it i think, im just after your opinions and suggestions
Cheers
https://www.sau.com.au/forums/topic/132971-gcg-highflow-r33-build/
if you want just ~210 odd rwkw you should be fine with the stock injectors and afm. otherwise, the mods you've listed are more than suitable.
if you want more, some 550cc injectors will help and maybe consider a FMIC that flows a bit better, if you are spending 2k on a turbo to make the power, dont just spend $450 on a full intercooler kit. Get one of the Blitz/Trust intercooler kits.
Your on the right track there mate to get the full potential.
- injectors, JDM manual S15 480cc are probably your cheepest option but may be hard to come by. Nismo ones from www.nengun.com are a direct fit 555cc will be plenty big enough and easier to tune than the 740cc's
- I highly recomend the Z32 AFM for a smoother tune
- cams will help also the tomei poncams are proven performers you can get them from www.nengun.com.
- I think the hybrid or copy cooler will be plenty good enough
With the above mods 250rwkw is achievible maybe more but its better to aim lower with your expetations.
Also do a search for threads by sydneykid and gcg highflow
cheers
Thanks for the help guys i appreciate it..
Well im pretty much sold on the hybrid cooler just for the price and opinion of others who have them.
Also i didnt realise the bosch 044 can be mounted in-tank so im now going that route.
As for injectors ill go with 550/555 (depending on brand) just looking around for the cheapest price/good brand, etc.
Z32 sounds the way to go..
But as far as turbo choice, im stuck between the gcg highflow (450hp) or a GT30 which is internally gated and has a rear housing to suit the rb25. These are both the same price but the catch is the gt30 needs oil and water lines to be changed around. Anyone have a suggestion here?
Cheers
All depends on what u want...
A mate may be able to help you on here, he made 330rwhp with stock injectors and is getting a proper tune soon! Gcg hi-flows are good on rb20s and awsome on rb25s
You can always go a vg30 exhaust housing if u was searchin for more lag/power down the road with the turbo too! Lots of options
    • Ha ha ha, this stuff they had was installing Toshiba PLCs that were made some time in the 1990s, and they were replacing GEM80 PLCs. To let those two talk (staged upgrade along a ~1.2km long building that was split into 4 sections), was a bunch of WinXP machines running Java gateways... There was no way to put something like ProfiSafe in... Most of the HMI machines were WinXP, with Java program, with a custom button board emulating a keyboard... About the only buttons in the operator stations that went direct to the PLCs was the eStop. There was some interesting design stuff in that place...
    • Stock bypass valves are good for plenty of boost.
    • Check for fuel flow out of the outlet end of the rail. Check for spark. Try to start with aerostart (or pressure can brake cleaner or similar solvent in a car) prayed in through TB. If you have fuel and you have spark and it will fire on substitute fuel, then seriously suspect that E85 sitting for ages in your fuel system has destroyed something and put it in your injectors.
    • Nissan stock oil pressure is typically about 1 bar at 1000 rpm plus about 1 bar per thousand revs on top.
    • Luckily for safety applications, with dedicated links not being used for any other traffic, you simply run ProfiSafe (or an equivalent safety comms protocol from other vendors) over the top of ProfiNet (if that's what you're using, or Ethernet IP if you're stuck in the world of American PLCs and not verking vis ze Chermans) and the redundancy is more about being able to know that you need to cause a system diagnostic lockout because you've lost one of your comms channels, rather than not knowing that you've lost your only comms channel. Granted, heartbeats and all that are possible and useable and all that, but some safety applications are are so time critical that you might not be able to afford a few milliseconds until the next check.
