Hi All
I have talked to the local Tein dealer here in brisbane (in moorooka) and he says they have had their Tein suspension re-engineered for brisbane/australian roads specifically.
Can anybody here running this suspension let me know how it handles.
ie does it bottom out easily, when you load up the outside wheel coming around a corner and there is an undulation in the road does it understeer easily, etc.
https://www.sau.com.au/forums/topic/132975-tein-suspension/
I have them. I liek them. They are not harsh to ride in, they handle very well. My car is used for local motorsport events and is very competitive. The adjustments are quite good and give a good range. I dont run mine in the lowest possible height, i run it about 350mm. Dont have it bottom out unless hitting a really big bump. Plenty of travel in both directions.
Just my 2 cents.
Regards
R Dirty 3
https://www.sau.com.au/forums/topic/132975-tein-suspension/#findComment-2465273
I have TEIN HA's, jap spec ones (no Oz modifications) an I love em, they handle great an the ride isnt too overly stiff. They've never bottomed out on me, but I dont have them on lowest setting either, mine are around the same as R DIRTY 3's.
what suspension you should choose depends on what your intended use is, also your budget.
https://www.sau.com.au/forums/topic/132975-tein-suspension/#findComment-2465508
Very good point abcent. If you looking for mainly road and minor track like me, then Aust spec will suit ok. If more track or more "spirited driving" then maybe something else is a better choice. Budget may also play a large part of your decision to.
https://www.sau.com.au/forums/topic/132975-tein-suspension/#findComment-2465602
Thanks for the comments guys
I am primarily after comfortable city use with spirited weekend track use.
I was told that getting a set of Teins for all four corners would set me back $2300 which i am fine with as long there are people around Oz that have these ones with the "special mods" that live up to what they are claimed to do.
https://www.sau.com.au/forums/topic/132975-tein-suspension/#findComment-2466212
i'd think that by "special mods" they'd mean softer spring rates? You can get softer rate springs for em through RSR i think? so chances are they buy the Tein's minus springs, buy RSR springs, an presto...."aussie modded" Teins. I thought about doing this after initally installing by jap Teins, but using the car for a few more motorsport events recently, and glad I didnt. Also Teins dont come with any upper mounts (not for that price anyway), so they'd be re-using yours, in which case you may wanna put new bushes in there....more $$$
Being that TEIN's have 16 step dampen adjustment, I cant see them modifying the actual shock it self, there'd be no point.
https://www.sau.com.au/forums/topic/132975-tein-suspension/#findComment-2475548
Spring rates are the same as the jap models, the changes are in the dampers.
For the price you are quoting i'm assuming superstreets?
Also consider that the springs used in the super streets are a 70mm diameter vs the more commonly available off the shelf 65mm springs used in most jap coilovers, but even tein springs are reasonably priced and there is a fair range available.
https://www.sau.com.au/forums/topic/132975-tein-suspension/#findComment-2475675
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
