R32 Gts-t, Pod Filter Box
I'd leave the series 2 bumper on there. Anything else is gonna be a bit janky TBH :p (or at least keep it)
Thanks everyone … will give it a go. Hope the added back pressure doesn’t screw up my weak rich idle issue I have… would be great if it helped it😃
Has anyone used 16 x 1.5 to - 6 orb to AN fittings on the pump? Are you still able to get the electrical connectors (chassis side) circled in the attached image and how could I the part numbers if so? I believe the pump I'm using is an R34 vspec/hydraulic locking rear. Thanks
Yes, just throw some gaskets at it and put it back in. As long as everything is actually designed to bolt up together it will all go back together. My CA compliant exhaust for example can only fit with the specific catback I gave them. -
By aligatorcat · Posted
Sorry I missed this. I ended up getting one locally. Appreciate your time to help.
