  • 7 months later...
J-TUNED AUTOMOTIVE.
Great service. Knows his skylines.
From service's to installation of all aftermarket items on all vehicles.
Ask for jay
contcact numbers are: 0423209139 or (03) 95431110
address: 35 hume street, Huntingdale 3166
Edited by King of kings
  • Like 1
  • 3 months later...
  • 2 months later...
  • 2 months later...
J-TUNED Automotive.
35 Hume Street, Huntingdale.
0423209149
Took my stock as a rock 34 gtt in fairly crappy condition to Jay earlier this year having NO idea of how or where to begin my skyline project, and on the verge of giving up. Since taking it there I've only experienced positive things. It's not just "you get what you pay for", he puts a LOT of time, effort and passion into his work.
-Awesome workmanship
-Organised
-Passion in his work
-Good prices
-Great bloke
The car is now producing 340rwkw and running flawlessly. Trent from Chequered Tuning personally told me that all of Jays cars are a breeze on the dyno and have no problems what so ever.
He is the real deal!
  • 2 months later...
anybody know the name of the interior shop that operates behind MiColour?
on the lookout for someone interested in doing a custom-ish dash mats group buy.
Wayne's Motor Trimming in Ringwood does good work, but not sure if he'd be keen on multiple dash mats for imports....
  • 1 month later...
Hello All,
First time poster here.
I'm looking for a workshop (western suburbs preferably) that can assist with my build
VL Body with an RB20DET. The under bonnet wiring is a mess so I'm looking for a workshop that's had experience with my kind of build to assist.
Edited by MXrecord
  • 2 months later...
  • 4 weeks later...
Could anyone recommend a good smash repairer, panel beater around Coburg, VIC area?
Someone that's has knowledge and accessible to Skyline import parts...
Hey mercyseat, did you manage to find someone? Looking for a workshop to repair my car as well http://www.sau.com.au/forums/topic/465560-accident-repair-preferably-around-northern-suburbs/
  • 2 months later...
There is a new business started in Hoppers - YourGarage.
Its just like a workshop, except you do the work. They supply all the equipment - 3 hoists, all the spanners you could ever want, hydraulic press, engine crane, welder, lots more. You pay an hourly rate for use of the shop; the rate reduces for 3 or more hour blocks. You can do anything from a simple oil change to an engine swap.
Its located at F8/29 Graham Ct Hoppers, ph: 8360 7033, yourgarage.net.au
FYI - they have a show'n'shine happening this Saturday Sept 24 - free to come and look.
  • Like 1
  • 7 months later...
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
    • but any other area than the bulge you are talking about will just cave in then? The front driver side is pretty bent so I don't know if that will work the way it is now. I can still kinda make out where that bulge is/was but it looks like the position of it also changed due to all the mistreatment? Hard to tell
    • Absolutely. Look very closely at the photo (of yours) that I took my second snip of. See how the sill is thicker material right behind the pinchweld, where the two notches are? That is the factory reinforced area for lifting. That pad is supposed to carry the weight. The factory jack (go look at it, and how it interfaces with the car at the pinchweld) shows you exactly how the load is carried from the car to the jack to the ground.
