Tokyo Drift Areas And High Speed Runs
If you're looking forward seeing some drift spots, when you heading up Tokyo area, you can try go to Urayasu (浦安) area which is near Tokyo Disneyland, every Thrusday or Friday you may able to find many drifters (野郎), of course they wont drift near the Disneyland area, they will first meet at some convineient store, like 7-11 or Lawson nearby, then they'll drive to some factory area.... Nowadays police take drift very seroiusly, it may be hard to see any, it really depends your luck.
If you also interest top speed (最高速) , or if you have mates around Chiba area, you can go to AQUA line in Chiba area, it's actually a long fast express tunnel which connects Chiba Kisaradu (木更津), Yokohama (横浜) and Kanagawa (神奈川県), this AQUA line is a good run, but each run will cost you 4000yen in tolls, so people will just do a U turn in the parking area and do a few high speed runs... since this express line very expensive, not many normal commuters will use it, so Friday night you might able to see many zeroyon ゼロヨン (0 - 400m drags), a few years ago Wangan Kousoku 湾岸高速 was the best place , but nowadays there are too many accidents, so it might be hard to see any runs on the Kousoku 高速。。。。there might be a bigger drifting scene around Osaka.
Regarding getting parts in Upgarage...I bet it might be hard to get good parts around there, since I think many good parts have already been bought by other poeple or something, and Upgarage prices aren't really bargains anyway, the best place to get bargains would be on Yahoo auctions, Goo parts, and some internet online stores. If you want to find some wecking yards in Tokyo area, I can list you some or search for you, and nowadays finding places that do front cuts are very hard to find since the govenment is changing the rules every few years. You could try Osaka, it might have more wekcing places, I have heard that at TRIAL they help customers with front cut/half cuts... Anyway good luck for your trip.
By 350z33
  • 4 months later...
  • 2 months later...
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
