  • Replies 65
Posted Images
Are these site trust worthy and is it in australian dollars cauz the prices seem too good to be true.
not sure about greenline, but nengun is in aussie dollars and i've bought a fair few things from them, so yes they are trustworthy :nuke: sometimes they take awhile to send the goods, but they are generally good with email responses, and their prices are the cheapest i've seen! :)
just a quick question about the safc2; i was reading that they can display boost pressure so could it be used as an accurate boost gauge?
im looking at getting one from negun also, how many people are looking at getting one? should do a group buy :(
from what i have read on this site i think that the safc is realy only any good if you dont plan on modding your car to much. they wont run much bigger injectors so if you are thinkng of upgradeing your turbo later dont bother as you will need injectors as well. the reason you see so many for sale again is because they have there limits that are passed quite quickly. but they are a good unit.
another cheaper option is to get one of the Jaycar digital fuel adjuster kits.. these are exactly the same and will do the same job if not slightly better. the jaycar unit has more load points than the apexi across the board but the later moddle safc2 has a full throttle setting which is said to be pretty handy. there was a group buy on these recently and the unit plus hand controler was selling for around the $100. for the DIY king well worth it.
here is a link to some more info. there is a lot of reading but most of it is on the boost controler so scim over that and have a read of the DFC.
http://www.skylinesaustralia.com/forums/in...showtopic=61207
this is correct, ive got one installed and now ive reached my power limits with my new aftermarket turbo and now need to get a power fc, fuel pump and injectors to achieve more power..
wont help too much on economy as it is tuned to decrease fuel ratios at over 60% throttle, and most of the time u drive the car at under that percentage.. this is how its tuned on mine anyways, depends on wat kind of tune u get..
either way, i was happy with it so far, increased a bit of power and overall performance, but like i said its limited to wat i want to achieve thats why im goin to be selling it soon and purchasing either a power fc or microtech..
Edited by MKDR33
They are definatly worht it. I had mine tuned this morning, First run 147rwkw with map all over the place. Then we played arround with fuel pressure and got it up to 165rwKw and a good place to start, 3 hours later managed to get a peak of 207rwKw@12.1 psi BUT massive spikes as the boost controller could not do it's job. So backed off to about 10psi and amanaged a nice 187rwKw@10.2 psi.
THE SAFC II made a hudge differance, and littel by little the power came up SO i think for $350 plus tunning, well worth the money.
Mods are, SAFC II, FMIC, Dump and exhaust 3", HKS pod, bleed valve boost controller, FPR, and a new pump, mine died.
here is the proof, as you can see the boost sux.
Edited by WogsRus
so it a worthwhile mod then? whats the average power gain using the safc2? seems some people get 10kw and other 30-40kw.
depends on ur other mods, eg intercooler, POD, exhaust systems, turbo upgrades etc.
does the safc2 display boost and is it accerate?
no it doesnt display boost pressure..
    • So left off with high hopes of having a gearbox in pretty quickly........ Got the adapter plate that week and had to chase a few threads and work out how/where everything goes as no instructions. Got the adapter fitted, test fitted gearbox and found had to cut and shave a few things. Tunnel required some hits with a decent hammer to give some clearance on passenger side but it fits with no problems,  could fit a 8hp70 with a little more work. For a cross member I wasn't going to spend $1100 on so shiny machined piece. Went through a few designs and remembered I had a gktech s chassis to cd00# cross member. Fitted that and found its close enough with a few extra bits welded so have gone that way and still a work in progress.  After this got into modifying the intercooler with some bends and clamps. I was procrastinating on this as was not keen to cut up and weld it myself but happy with the outcome.  Onto the radiator shroud and oil cooler mount. This thing took way longer than I thought it would but having to add an extra oil cooler for the trans and wanting everything within the chassis rails its good enough for now. It mounts to the chassis and gives plenty of room for lines and pipes. All the coolers are rubber mounted and sealed the shroud on the top and sides, will use some tape to seal the bottom gap of about 10mm. 20250508_111500.mp4   Next job was to build the new diff and after a delay with a friend got built this week. I ended up putting it all together with supervision and was good to learn how to set one up correctly. I ended up going a 3.69 ratio, nismo 1.5 way gt pro with gtr Axel's. Stripped it all down, gave all the parts a good clean, pressed on new bearings and set backlash. Was good working in a clean assembly room with all the gear. Once got home wire wheeled the case and hit it with some rollbar/chassis black paint. Got a few more bits done but will leave them for the next update.
    • That could be drilled, ground and welded. Would stop it progressing and leaking. But that block shouldn't be pushed very hard, as what you see there is a massive warning sign. But that fix also isn't going to happen properly with the engine in the car, and assembled. So you're looking at anew block if you're doing all that work anyway.
    • It's not as simple as it is being made out to be. It s not hard, but there are things that have to be done. Am busy right now, but will try to essay later.
    • Pinout is different to my knowledge, but you should confirm to be sure. Also you will need to adjust the VQ table in Nistune to suit. I would still recommend sticking with recirculating BOVs, I'm not sure if the R35 card MAF will fully resolve stalling caused by reversion/throttle lift.
    • What issues are those? Previous owner said it wants to stall sometimes. We did test drive and it was nice and smooth so it will be sporadic or idk. And if i just change MAF(the sensor to R35 version) it should be better? And as i asked...is it like "plug n play" with oem MAF from R34?  This is a MAF from R35 right?
