Hey everyone,
I've searched and searched for the topic but can't seem to find it. Apparently there is one but oh well.
I have my RB26 on the stand out of the car and i want to mod the oil pump collar on the crank to improve strength. I am curious who has had it done in Brisbane. I need a contact that i can trust to do a good job at a good price. If any of you have had this done in brisbane please let me know.
Cheers,
Deren
https://www.sau.com.au/forums/topic/133063-r32-gtr-oil-pump-collar/
correct. Suited for use with aftermarket or N1 oil pumps. Bigger gear, bigger drive, alot better.
For our rb30 crank we got PLR at Brendale to do it for us, cost like $80 bux i think, to machine the crank and countersink grub screws and fit collar. Got it back after a day or two.
Edited by r33_racer
but you'll find he wont recommend using the JUN collars, he'll like to make up his own...
Yeah well for the additional price of the collar plus fitting i'd be silly to go that way. Im sure his custom one is fine :ermm: Looks like i might have some engine building work for him also..
Yeh Jhh will do it for around $150.
So its $150 send the crank up and get it back?
Or Send the crank up, $150 for labour, then extra for the collar?
    • Does it make a difference in your turbo having a shorter life if you have a cat converter as it causes that back pressure versus less/no back pressure with a decat? (Not sure if this is accurate) Also slightly different question if you went from a oem cat to a decat or vice versa will it require a tune? I heard if you change the dump pipe onwards it requires a tune?
    • No. Have only gotten as far as contemplating the task of having to put in the required fairly heavy wiring and fusing to run it (along with the big alternator), and preferring not to. But otherwise, it would be nice to have a little extra freedom as to exactly where the compressor is located and free up some space around the exhaust side of the engine.
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
    • Bit off topic maybe but has anyone had a crack at one of those aftermarket electric compressors ? Bit of a search came up with one put out by Speedy Air Spares. Looks interesting and looks as if you'd have to run a big arse alternator. Found this out after the fact as my air con compressor packed it in and soon after my alternator ! !
    • Yes. Needs new ports. Usually just achieved by screwing an adapter onto them. Be aware that any AC compressor that hasn't been used in a long time will very likely have dried out seals and will not hold gas. Oh, and obviously you will require a new receiver-dryer also.
