  • Replies 44
ironic you should mention them as only today i went looking for their website - haven't heard anything about them in ages was unsure if they still existed.
I haven't bought anything off them in the past. Apparently nengun.com is pretty good too.
https://www.sau.com.au/forums/topic/133067-green-line/#findComment-2465362
I've used them a fair bit. Good service and I found them a fair bit quicker than Nengun. The website doesn't have the wank factor of a shopping basket and some of the pics are a bit small, but if you know what you're after who cares.
As with any online shop ask whether the gear is in stock before ordering. It saves alot of heartache.
Jon
https://www.sau.com.au/forums/topic/133067-green-line/#findComment-2465556
We'll see how good greenline are in the next day or so.
My carbon fibre cooling panel finally arrived after being on back order for a few months - open the box to find my c/f panel chipped and cracked. Who ever packed the box thought 1 layer of bubble wrap and 3 sheets of newspaper was adequate packing for such a fragile item.....
Emailed Jason this morning with pics - havent heard back as of yet.
We'll see how good they are - ive yet to buy turbos, computer, pipes, etc - so alot of potential business depending on how they resolve this.
Will let you know.
Daniel
https://www.sau.com.au/forums/topic/133067-green-line/#findComment-2468468
Back when i had my 'line, i ordered a tonne of parts through Greenline including expensive stuff like turbo kits. Never had any problems. Saying that, it all arrived undamaged so hopefully IMACUL8 will have no dramas. Word of mouth can aide or kill a business quickly.
https://www.sau.com.au/forums/topic/133067-green-line/#findComment-2468520
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
