i might need to get my turbo hi-flowed sometime soon coz right now i need to floor the pedal to get any real response from the turbo...under normal acceleration the turbo kinda feels really lagging ...but on 2nd thoughts that might have something to do with AFR's ...maybe if i lean it out just a bit on the low end then the engine should feel more responsive...any thoughts?
Hmmm this sounds like there's a problem somewhere. A highflow turbo really wouldn't be a good idea unless you have a problem with your current turbo (my situation), or you have the supporting mods to make it safe and worthwhile (my guess is fmic, boost controller, safc or equivalent, and exhaust).
The stock turbo is not what I'd call lagging or lacking response. Its actually very responsive but cannot handle a lot of boost (ceramic wheel). So I'd want to be sure there are no issues with your current setup before looking at a highflow option. :laugh:
  • Replies 54
Posted Images
with a full exhaust, gcg and 13psi, my S1 made 160awkw
i wont be slapping it back on the dyno, but dont worry, i wont have forgotten what boosting feels like :)
Obviously they weren't the only mods (boost controller, fuel or afm-related piggybacks, bigger cooler?)
Thats roughly the sort of power figure I want to end up with. Not planning on running huge boost, probably around 12-13psi would be nice. Just a matter of getting the supporting mods to run that kind of boost. I think at 8psi (gt30 - i think that means more air than stock at same psi?) I'm running into cooling problems but not sure. Its s2 so its got the r34 gtt cooler.
I'm thinking fmic, exhaust (not sure if I need full 3" or just catback? anything that will reduce lag would be great), and safc.
Already have boost controller (not installed yet).
well i have the s1. current mod on it is just a 3 inch exhaust turbo back. currently in hand
1. apexi safc (3 units actually - looking to sell off 2 ..interested? ..look in the for sale forums..lol <<free advertising)
2. blitz twin solenoid boost controller & greddy profec b <<can't decide on which one to use and which one to sell off. ...prolly go with the profec b
Dont have the $$$ for an FMIC at the moment...so with just the boost controller, afc and exhaust mod...what do you reckon is a reasonable ask in terms of rwkw?....im hoping 130@12psi (would this be too much for the stock cooler?)
Id suggest youd pull 130 easy up to 140 awkw at 12psi with that little list.
nothing wrong with 140awkw, enjoyed that setup for a while (with a R34 SMIC)
I admittedly enjoy the 160awkw at 12psi a lot more tho
.............. and I suspect I'll be a fan of 190-210awkw at 1bar too :P
with the 'cooler, just buy a cheap core and a pipe kit (ebay, lol) and mock up a return feed pipe setup. not expensive at all.
Yes, actually they were the only "power" mods. Complete stock untouched ECU. Just boost upped.
Had a GTR FMIC too, but that isnt making power on its own, only improves the flow. For example, i'd have made the same power with a stock SMIC but it just wouldnt have been as early/smooth. Plus, I dont really think a fan blowing on a cooler on the dyno can help THAT much.
Im expecting around 140awkw with the high flow and stocko rest. Might see how far I can push the boost until I hit R&R :P
SK reckons a stock R34 sidemount willdo 200kw. There is a thread in the DIY section onan R34 conversion :P:)
SK reckons a stock R34 sidemount willdo 200kw. There is a thread in the DIY section onan R34 conversion :):nuke:
It may be able to cope with it but how well?
Cooler air is always better so a better cooler will still improve things over the stock cooler. :)
Would be interesting to actually see the difference. :)
Im expecting around 140awkw with the high flow and stocko rest. Might see how far I can push the boost until I hit R&R :)
Sounds good.
So that makes me wonder. If I can get away without touching anything on the fuel side (injectors/fuel pump etc) I'd be very happy.
I'm still well away from R&R (AFR=11 at the top end so a bit of room to move) and my fuel economy is better than before so a bit more richness isn't going to bother me.
Still puzzled as to why I have only 100awkw with a s2 and gt30 turbo running 8psi. Maybe I have some other problem somewhere.
The main 2 things I want is bigger exhaust and bigger cooler (if i need it) so if I can get by with just an exhaust for a while that'd be great. Getting manual boost controller soon so that will be good for later on. Should be able to bump it up to 10psi for now tho - nice round number. :nuke:
SK also did an evaluation on the air deflector. I've got one on order
The colder the air the denser it is. Denser air has more Oxygen = more power. :):nuke:
I dont see how a small intercooler would make a lot of difference on a short dyno run unless it is acting as an airflow restrictor - ie a boost pressure drop across the core - which can happen if you are running a large turbo. I believe this is what SK is referring to when he says a stock R34 IC is good for 200 kw (in terms of flow).
The size of the IC only becomes an issue when it is unable to dissipate the heat being generated by the turbo. Which is only going to be problem on the road on hot days or after a number of dyno runs close together.
I definitely think the most critical part of the exhaust is the front dump pipe upto and including the cat. The standard stagea dump pipe has a small cat, barely 2.5 inches in diameter only 12 inches from the turbo before the exhaust moves down the pipe 3 feet to the next cat. This kind of back pressure will stop your turbo spooling up freely. That is why everybody raves about the new found mid range torque they have with a decent front/dump pipe setup into a 3.5 inch cat.
Edited by 3intheBack
I didn't have any boost pressure drop on the dyno (if thats what you mean) - it held 8psi very constant, only dropping slightly at the very top end (say down to 7.5psi?). I'd probably look at replacing the entire exhaust if I was going to do that. As a minimum I'd go for dump/front pipe + cat and make sure the catback section is bolted on to make it easier to change later on. But for the remaining cost of the catback section its probably worth doing the entire exhaust at once. :laugh:
pressure drop across a core is when you measure the difference between the boost on one side of the core to the other.
your car would have held 8psi constantly yes, but what if there was a 10psi drop so your turbo was actually blowing 18psi. See the lack of efficiency.
Alex, wouldyou put in two boost gauges? Then you could see if there was any differential between tourb boost and what was actually getting to the inlet manifold . Or would that be a waste of time effort and money? :):)
ok. still not very clear to me how it all works. All I can think of is that because my exhaust is so restrictive (stock exhaust) the backpressure will build up boost pressure quicker so it will still read 8psi but the airflow is less since the turbo is having to struggle against backpressure to actually put air through...does this make sense? am I way off track here?
Am really hoping a 3" exhaust will fix the lag and low kw issues. The gt30 turbo is a big jump from stock and I went on the recommendation of the guy that works with turbos all day that installed mine. But it seems it never really reaches its optimal efficiency until about 4000rpm. If an exhaust or any other mod is not likely to fix this, then I have to say the gt30 will be coming off again and a unit more similar to stock going back on. All along I've been thinking its just because of the exhaust - but I dont want to spend $1k on an exhaust only to find its still very laggy.
search R33 exhaust on ebay; you'll come up with a 3inch bellmouth dump pipe from turbo to cat, and a 3inch highflow skyline catconverter. $400 delivered for the 2. Unleash the beast thats in your turb setup mate !
Did ppl know that a R33 skyline exhaust system WILL fit?, so buy a used catback system. It'll be 20cm too short, so cut it and weld on a 3inch piece. This is whats on my car, cheap but it does the job. 160awkw on the standard turbo is testiment to the efficiency.
Mate, you'll lose shiteloads if you go to sell the GT30 highflow now. Look around and you'll be able to knock up a full 3inch system for $800. Then you'll be impressed with the setup youve got, no doubt.
edit: modifying is never cheap tho, lol as we all know..... maybe look for a used safc too? :happy:
Edited by Tangles
pixel at the very least bolt on any 3" exhaust system. once you have done this you can reassess the GT30. like most others here i think it is a touch too large but (like tangles says) until you uncork the restriction on the exhaust side, the turbine will struggle to turn the compressor efficiently. the response should improve dramatically once you do this.
we tried both split and bellmouth dumps on my stagea and the bellmouth made more power with less exhaust side restriction. i can't vouch for this being consistent as the common wisdom is to go the split dump due lower turbulence when the wastegate cracks open, nevertheless we chose what worked best in our case.
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
    • Correct. The ECU cannot read oil temp. (Well, I think it probably can in some situations. I did have the thought of potentially repinning the ECU when I was doing oil pressure). I am using this into the MPVI dongle, so that the MPVI dongle can read oil temperature. It is attached to a VDO gauge which is obviously calibrated to whatever curve the sender actually is using. This would be easy if I could setup a table of voltage to temperature like many sensors, but it appears I cannot do this and can only setup the transform rule which appears to be Input (voltage) x Multiplier, and add an offset. This to me means it MUST be linear. So it may be a complete waste of time wiring this into the ECU. The idea was that the MPVI3 has standalone logging. I wanted to use this instead of a laptop with serial cable (for wideband) for long datalogs. Given the wideband also has electric interference, I may never trust this either in a world where the serial wideband and the analog output wideband do not agree. Last time I did a trace I could see the two wideband traces follow each other, but one was a little leaner than the other. I plan on playing with voltage offsets and actually driving the thing to see how close they correlate. If they never correlate... then, well, maybe I'll never use either. Ideally I'd like to have the Analog wideband read ever so slightly leaner than the serial one, because the serial one is 'correct'. Tuning the car to be ever so slightly too-rich would be the aim. Not needing to have a laptop flying around in the footwell connected with cables is... an advantage. About the only one from the forced upgrade to MPVI3.
    • Hopefully not, since he knows the fuses work ha ha ha
    • I don't think he's got it on a gauge and on the ECU. I think he's got it on the gauge and on the HPTuners DAq thingo. Remember, we're talking about oil temp here, not something that the ECU is actually interested in for its own sake.
