hey all, i just got my new clutch and im eager to get my flywheel machined and get the new clutch in. Does anyone know where a good place is to get new flywheel bolts? Does anyone know if a nissan dealership will sell them or if there the same as vl's? Let me know, cheers
https://www.sau.com.au/forums/topic/133084-r33-gtst-t-flywheel-bolts/
Why do you need to replace the flywheel bolts?
If you absolutely must replace them, only use genuine. You will need to tell them your VIN. I'm not sure if the VL ones are the same but I do know that the VL flywheel is marginally different in some ways.
Nissan.. around $5 each. They can get them in a day or two usually, if not in stock.
I would have though they're an important thing to replace with age.
They dont necessarily require replacement, if they are showing signs of stressing or cracking around the neck then definately replace, after all whats $30 bucks when it comes to holding part of your rotating assembly!!!!
