I need some advice on what could be a life changing decision.
I've suspected for some time now that my girlfriend has been having an affair. The usual signs. Phone rings, I answer, someone hangs up.
She started going out 'with the girls' a lot recently although when I ask which girls it is always "Just some friends from work, you don't know them".
I always look out for her taxi coming home but she always walks down the drive although I can hear a car setting off. As if she has got out of the car round the corner. Why? Is it not a taxi?
I once picked her mobile up just to see what time it was and she went beserk and screamed that I should never touch her phone again and why was I checking up on her.
Anyway, I have never approached the subject with my g/f. I think deep down I just didn't want to know the truth but last night she went out again and I decided to check on her.
I decided I was going to hide behind my car which would give me a view of the whole street so I could see which car she gets out of. It was whilst crouched behind my car that I noticed rust around my rear wheel arch.
Should I take it into a body repair shop or should I buy some stuff from the local auto shop and try to repair it myself?
https://www.sau.com.au/forums/topic/133143-life-changing-decision/
  • Replies 52
HAHHAHHAHAAAAAHAHAHA
gold
2 thumbs up :(:ermm:
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
