I have been having a problem with flat spotting.
I run NGK plugs with a heat range of 7 and on cold canberra winter mornings they flat spot until I get some boost over them, then they are fine.
I have tried using a heat range of 6 and they dont flat spot in the morning but they do flat spot with higher boost levels and they also knock a little higher (I am guessing pre-ignition)...So I am sticking with the 7's gapped at .6
Anyway could this flat spotting be the reason why my catch can has fuel in it? The catch can does not feedback into the inlet and I have blocked the PCV valve.
Also does a smaller gap rob you of any power?
Any ideas on the matter would be great
thanks in advance.
Edited by GunMetalR33
https://www.sau.com.au/forums/topic/133164-petrol-in-the-catch-can/
  • Replies 44
too much knocking or something else has caused your rings to lose their tension and petrol is bypassing them and its going round with the oil.
That's what I figured but there is no oil in the catch can and the compression in all 6 cylinders is within 10% of each other. If the rings were worn it would show on the compression test and I would think there would be oil in the catch can???
yes, smaller gap will rob you of power. why are you gapping the plugs so tight? 0.6mm gap is tiny. you should be somewhere between 0.8mm and 1.0mm.
edit: I have NFI how you are getting fuel in your catch can, but it's not good. 2. are you sure it's fuel?
well the petrol thing isnt...we had a similar problem in our race rb25det except the rings were shagged and the compression was down, regardless if they were all down the same or within a certain amount it was still happening, petrol in the catch can, not just oil.
I cant see another way of it bypassing and getting into the catch can.
With such a smal gap, you are probably not burning the fuel properly. Unburnt fuel is then being dissolved in the oil on the cylinder walls and taken down into the sump.
Open the gap. (usinga really small gap is only masking the real problem)
compresion test with fuel washing away oil on the bore is not a acurate test, remoove the plugs + the fuel pump relay, crank the motor over and let all excess fuel out, then re oil the bore and potentialy change the engine all oil together, lightly lube the bores with small amounts of oil then allow the car to sit for a lil while then perform another compression test..
Thanks for all the replies.
To answer a few questions:
1)Yes I am sure its fuel, very little oil, only enough to slightly discolour the fuel.
2)I run .6 of gap to stop flat spotting. Anymore gap and it flat spots. However I have removed a big restriction in my zuast since gapping the plugs down so I might gap them out and see what happens.
3)The max compression in was 150 psi in one cyclinder with the rest being within 10%. Most above 140 psi.
Could it be a head gasket problem? I am running 19 psi :P (yea forgot to mention that)
PS => if the rings are worn which I am sure they are (at least a little) how long will they last. Will they continue to wear or will they just sh*t them selves one day :{
Also how much for a re-build with forgies if I take the engine out and deliver it??? Just after a ball park figure. I am tring to save for a house :{
having spoken with Timmy and hearing the power you are putting out with standard internals it would not surprise that it is starting to die. Standard internals + the power you are making = upcoming rebuild... sorry to say it :P
oh also forgot to mention alot of the SAU Canberra and even Sydney guys who have had rebuilds have gone and seen Greg @ proengines. Maybe give him a call he may be able to offer some advice. http://www.proengines.com.au/
having spoken with Timmy and hearing the power you are putting out with standard internals it would not surprise that it is starting to die. Standard internals + the power you are making = upcoming rebuild... sorry to say it :/
Yea, a lot of power to timmy is 140rwkw or what ever his old beamer used to make :mage: I have about 260 now and plenty of guys run that sort of power for a while. But I think you are right, engine is starting to get a little tired now :P
if hes only running the 246rwkw then stock internals are fine. As for 20psi and fuel in catch can also its missing.... What do all the plugs look like? If for some reason there is fuel in the oil look at the bigger picture your oil is f**ked now its thined out which will damage your bores.
I cant see how fuel gets into the oil, ie its sprayed into a chamber compressed then detenated and push out the exhaust valves.
You must have some bad underling problem eg craked head, head gasket to oil, valve guides, oil rings.
... I am running 19 psi :P (yea forgot to mention that)
There's the reason for your flatspot - the engine probably can't ingest air at 19 psi. Back the boost off a bit - I reckon 1 bar is more than enough.
I only just replaced the oil 1 month ago, I had 245rwkw before I shaved down a restricting turbo spacer to the correct diameter. Car is a lot faster now... I estimate about 260rwkw...
Plugs look good, a nice bronzy like colour but not too light...
So you reakon I should change the oil again? This motul stuff aint cheap :P
Yea, I will re-grap the plugs to .75 then wind down the boost till she stops flat spotting. Does anyone know the coversion between psi and bar, as in what is 17psi in bar?
If this is the case...maybe see if you can borrow a set of splitfires for a day and gap your plugs to .8. I still had major issues with those bosch coil packs (if you're still running them?) and haven't had a hint of a miss since I got the Splitfires
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers)
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
