Hey people,
I recently got my rb25 rebuilt about 5000km ago & we have now found out that there is a very big problem with power output etc.
I recently got a PFC installed & the best we could achieve was 138rwkw on .7bar with the following mods
forged piston set 20tho
gtr rods
arp conrod bolt set
race series main bearing set
bigend bearing set
nissan gaskets
nissan cam belt
pfc
fmic
3.5inch full exhaust
avcr (.70 Bar)
cai
stock turbo
stock injectors
Now the problem is not with the tune as we put it onto the dyno before the pfc went in and the best it got was 111rwkw on stock boost! so the was a gain of 27rwkw at the end with the pfc installed., the tuner said that it could have an extremely high static compression ratio or another issue.
so then we thought it was a turbo issue but we pulled it off yesterday & the turbo is fine! which means there something wrong in the motor! we did a leak down test & compression yesterday and these are the results
leak down test: this was done with the car not being started in 2weeks so its dead cold!
1 cld: 7%
2 cld: 5%
3 cld: 5%
4 cld: 5%
5 cld: 9%
6 cld: 6%
compression test: also done cold
1 cld: 120psi
2 cld: 115psi
3 cld: 125psi
4 cld: 125psi
5 cld: 117psi
6 cld: couldn’t do 6 as oil started going everywhere
so the were the results & we still don’t have a clue on what the problem could be! the compression test come up really low but couldn’t that be caused by a low compression ratio?
I guess if any one has had this problem or could shed any light on it that would be good.
Sorry about the crappy post but im not really mechanically minded!
Cheers
Alan
Edited by al_r33
https://www.sau.com.au/forums/topic/133169-rebuilt-rb25-problem/
could be a poorly calibrated dyno?
boost reference is invalid, its less than .7bar possibly?
umm...how come oil went everwhere from cyc 6?
That doesnt sound right at all
Check the timing, if the cams where touched, cam belt is on correct etc etc
why is your cold compression so low? The temperature doesnt affect it too much...its whether its wet or dry that affects the compression dramatically. But that compression should be around what 160-170. What thickness headgasket did you put in it, std nissan one 1.2mm?
atm my money is on the low compression.
i dont know why oil started going everywhere as the motor has heaps off\ parts of it atm!
the dyno is okk as i took it to another one just to see & they bascailly come up the same!
the cams were check and come up fine!
if its low compression how do you fix that?
Cheers
alan
and as for the headgasket i was aware that it was a std one!
Cheers
More importantly not why but where was the oil coming from?
My Rb30det stone cold with 0.040" piston bore clearance was from memory high 150's after a 10degree night. All pots were to my suprise exactly the same with only one (cyl 5) being 1psi down. That was after ~20,000km's.
I just pulled down my rb25 for a rebuild...and when i was checking the compression, i accidently left the oil feed line hanging above cylinder 6....and after checking the first 5 cylinders oil pressure had built up enough to ooze out and straight down no.6 spark plug...well 165 across the board then 240 odd in no.6 lol. First thing i thought of that maybe they did the same thing...however the oil feed on a std turbo is a steel line, so yeh...not sure on that one.
Cubes why do you have such large clearance? What was the spec sheet clearance for your Wiesco's?
The spec sheet on the wiseco pistons stated 0.0040" (from memory) for 24+psi or race.
Sorry I missed a 0 in the previous post. :)
I went a little overkill in the clearance department but suprisingly it only ever so slightly slaps (not noticable to the untrained ear) when cold.
that is very low power. and thats some pretty huge leakdown aswell.
ps. arp dont make bolts for rb's people stick vg30 ones in them (abit dodgy)
umm. are you sure the cam TIMING is corect. is the vct working or jammed?
how often do you need to empty the catchcan?
why was ir rebuilt?
is you cat rooted from the old motor filling it with oil?
Drop the exhaust, b4 the cat and do another dyno run. Keep an eye out on the boost levels, as these can skyrocket if the exhaust was stuffed.
For a fresh rebuild those figures seem very poor.
How good is the reputation of the person that rebuilt the engine? :)
haha yes 4 thou sounds better, i thought fark 1mm clearance..something not right there. Yeh we ran 0.0020" with the cp's and no conrod oil squirters :) just relying on splash and shes fine, no slap either.
al_r33 what clearances were run with the forged pistons that were put in? And do you have the spec sheet that came with your forgies? Maybe the clearances are way too sloppy and thats why your compression is shitty, power shitty and blowby in excessive amounts??? if thats occurring?
Edited by r33_racer
well that’s the thing the guy who did it knew his sh*t that’s why I found it hard to believe that he built a bad motor!
I don’t have a catch can!
the exhaust was replaced after the rebuild as with the other parts!
the guy who check the cam timing said it was spot on!
so I dunno what’s going on with it!
Cheers
Alan
What have other peoples leakdown percentages been after a rebuild?
When I bought my GTSR(Circa 1987), I got a leakdown test done before purchase and it averaged about 12% across the board which the mechanic said was reasonable for the kms listed on the odometer which stated 130k.
Now for a 5,000km engine to show leakage as high as 9% isnt that a bad sign?
What was the run in procedure? Maybe its a case of the rings having not bed in correctly?
Dude you have a big problem. from what i see here t think it is that the dude that built your engine used to big clearances, causing exessive blowbyand loosing compression. i did the compression test yesterday on a friends GTST R33 S2, with a stock engine and it gave me about 165 psi on all cylinders, it was so good that all were in 1% of each other. the problem i see here is that your engine is pooooooorrrly assembled, have your tuner pull the engine off and take off the head, make him check the piston to bore clearance, the only soultion i can give you if the clearances are to big is that your have to re bore re hone and put bigger pistons in again. 138 kw is even lower than stock, so id advise to check your engine again. i wish i could live in aussi and be of assistance but cicumstances state that i have to give my advice from the other side of the planet
i bascally drove the car for 1500km on no boost & no higher than 3500rpm.
can anyone suggest how you would fix this sort of problem if the compression is too low?
Even though i really don't think this has caused any problem, i beleive the problem lies with a poorly built engine :), this method of bedding in an engine is not the best.
If i get my engine rebuilt, i will be loading the boot with heavy items (40kg bags of cement), to add load. Drive normally as if you are trying to conserve fuel. Then every 200-300km give it a quick strong squirt. An engine is best bedded with varying loads.
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
