SECUR1TY, similiar as to how I ran mine in.
I basically drove half to full throttle every time I accelerated.
Its first drive was along the sea front that has lots of small round abouts so every half a minute it was seeing lots of load. :D
Basically the mechanic recons that it has a ratio of around 7.5:1 & that the VCT isn’t correct! He spoke to a few guys and they have had the same problem with a rebuilt rb25 with all the mods should have made 300rwkw but made around 180rwkw so the up the ratio to 8.4:1 or 8.5:1 and played around with the vct and cams & stuff like that and put it on the dyno & it made 330rwkw @ the same boost & same tune!
So they have suggested to me that we raise the ratio to 8.4:1 or 8.5:1 & muck around with the head & get it back to the dyno for more tuning!
Does this sound like a solution or what?
Also does anyone know anyone that is making decent power of a ratio of 7.5:1?
Cheers
Alan
Edited by al_r33
The low comp won't really affect power that much. But it will allow you to dial in an unusual amount of ign. timing.
IF the VCT is out it 'could' be bleeding off cylinder pressure?!?!
I would have thought if VCT were out so much as to affect a comp ratio test it would show up with a a crap idle.
BUT.. One concern is the wavy compression results. So that again brings us back to an iffy rebuild. And then the oil going everywhere?!?! WTF.
nar the oil was comin out the oil line for the turbo! plus the car is barly drivable atm eg. wont idel & i allways have to keep the revs up or it goes to stall! but i think that is being cause by a faulty afm or busted ic hose!
but i have tacked down the guy who built it & going to talk to him as to why he would build an engine with a compression ratio of 7.5:1.
Edited by al_r33
7.5:1 is 1980's turbo style.
When the tuner did his thing, did he push it to the point of detonation with boost and timing then pull back for saftey? Just wondering if it's low CR and the tuner didn't go to the edge to see where it was.
That's still only an alternative to what every one else is saying about a really poor rebuild which seems more likely at this stage.
Yer he told me that he did push it to the point of detonation as he said he physically coulnt dial in anymore boost or timing & then he backed way off! It wouldnt even make more power when he would lean it out!
im getting to the point where im nearly over the old skyline!
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
