I'm having problems bleeding the clutch on my R32 GTST. I've bled it so there's only clean fluid coming from all three nipples... no air... but there is still absolutely no pedal feel. Does anyone know whats going on??? :ninja:
https://www.sau.com.au/forums/topic/133213-clutch-bleeding-problems/
Well i'm guessing there's a lot of air in them as i've just done auto to manual conversion so all lines were installed with nothing in them.
What do you mean by "back off the master cylinder" ?
For your future reference aftermarket (Protec & PBR) clutch master cylinders and slave cylinders can be picked up for ~$70 and ~$40 respectively.
When bleeding the R32's clutch I start with the master cyl, then the center box and then the slave, then do it again.
I've had a few issues bleeding mine in the past so I removed the center box and length of lines. I simply bent the metal line that runs in to the box back 180degree's in to the rubber hose that runs to the slave cylinder. Works well and actually provided better clutch feel that makes driving a ceramic clutch just that little bit easier.
Some have suggested this center box and length of lines are there to help keep the clutch fluid cool. I'm not so sure; what temps does the clutch fluid really see? A half decent dot4 boiling point is ~250-270degree's, if fluid temp was really an issue they would have set up something similiar for brake lines that see much higher temps that a slave cylinder.
Hey Cubes, where from?? I'm having similar issues as Psymon!
Edited by manage13
U can get dud new replacements though, as i found out. I replaced my master and bled it but it still had a slow leak ( put your foot on the pedal resting and it would drop slowly)
If the tiniest bit of dirt gets in, it can fark the seals.
I did buy a set for one of the guys interstate and posted them out to him, so i may be able to do it again if ppl didnt mind paying for my time/petrol to organise clutch master/slaves from all clutch and brake here in SA :cool:
I got a IBS slave cylinder to fit an rb20 box and it was about $30 from a brakes place (any brakes / clutch place that can get IBS should be able to get it)..
http://www.skylinesaustralia.com/forums/in...slave+cylinder#
^^ All there
It's much easier to bleed if you spend $70 and get a one-piece braided clutch line as well to get rid of the twisty pipe.. then there is only two points to bleed.
Predator;
Instead of the braided clutch line I simply removed the centerbox and bent the line 180degree's in to the rubber hose that runs to the slave cylinder.
Works well and is free. :O
EDIT: Checked the link.. I've just repeated myself. lol
you can do that as well if you like :O when going from auto to manual you have to track down / buy the extra bendy pipe.. in my case was easier for me to order a new one.
Psymon I hope you don't mind me highjacking your thread for a little while but I have a similar problem to you. Hopefully someone can help.
I have been bleeding my clutch for the past two weekends for more than a few hours. Yet the pedal pressure increases slightly however when the car is started the pressure of the pedal drops a little. I can’t see any visible leaks from the slave and I believe I have got rid of all the air pockets as I have bled the clutch more than a few times now. Can anyone hazard a guess to what my problem is? Has my slave had it?
Thanking everyone in advance.
hmm OK I guess it might be GTR only...it has a vacuum line from the manifold to a small booster at the master cylinder. When the car starts the vacuum makes the clutch pedal noticably lighter.
Hi Duncan, thanks for the reply.
The clutch is much lighter when the car is running however I can't select gears. Also my clutch used to rattle when the clutch pedal was pressed down now I hear no rattle. Any idea??
Did you try bench bleeding the master cylinder?
Sometimes when you try bleed it in the car when the master cylinder is new, and you keep pumping it, the cups inside the master cylinder can turn inside out.
So when you bleed it fuid still comes out when the nipple is open, and when you close it and pump the pedal, it doesnt hold pressure and the piston just passes through.
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
