My car wasn't optioned with the factory A-Pillar tweeters, but I have found some a-pillar tweeter trimmings and was wondering if I bought them and fitted them to my car if you could fit aftermarket tweeters (focals to be specific) in them?
here's come pics of the factory tweeter trimming:
Theres not as much room behind the A pillar trims as it looks so fitting aftermarket tweets may not fit too easily behind the factory grills. The factory optioned tweets are quite small.
Give it a measureup and see, some of the focal tweets are fairly small so you never know I suppose.
I looked into it when I was doing my install.. Not enough room.
And from memory, the little rectangle doesn't pop out, it's just a groove in the plastic if you didn't have the tweeter option. You probably would have to cut the holes out?
Stylish.. now THAT's doing it right!
If you can get your hands on the pillars, wouldn't they have the tweeters still attached?
Or is the quality of the optional tweeters lacking somewhat?
Naww bro! Get two a-pillar guage-holders, and then stick them in that. Then light them up with a bright blue light and write "NISMOHKSGREDDY" on them.
;op
Yep, but I was going to replace the whole panel with one that had the tweeter option :O
nice , neat and only you know what is under it :spank:
finding them could be fun though.
what about the tweeters on the r34 pillars? can they be replaced by aftermarket?
never tried. I think the one I have coming up on friday has them so I'll look.
If you have $600 focal speakers (very nice) you don't want to be mounting them in the A pillars as the positioning is extrememly poor sound wise.
I had a professional install done on mine with a pair of focal split's, and they mounted the tweeters at the back of the dash board (tilteded on an angle), paying great attention to the positioning and angle they mounted at.
If your spending the money of this sort of quality gear it;s really worth positioning the speakers correctly. Extremely happy with mine, they really look quite neet.
ahh thanks for the tip mate.
I have heard alot about tweeter positioning, if you ask FHRX he will suggest mounting them in the foot well, other people suggest near the windscreen, and others about a hand space from the midbass driver. I guess it all depends on personal taste. Chris Rogers will prob suggest another place again :dry:
Yeah mine are mounted near the windscreen.
Other thing is when your installing quality gear you really must sound deaden the front doors to get the most out of it. Really is amazing the difference it makes. As with everything it must be installed properly, if you can afford it Dynamat Xtreme is the best, but some of the others are OK.
Heaps of info on sound deadening in these forums.
I have just fitted a set of pioneer splits to my front doors, I also was after the clean and tidy look so i sprayed the silver tweeter trimmings matt black. The combo of dynamat extreme on the inner and outer door sheetmetal and the positioning of the tweeter is great, the tweeters literally scream at you, not like some other tweeters ive seen where you struggle to hear them. Heres a pic of my door setup.
    • Yes, while being... strictly unnecessary. Tuning is a bit like quantum physics. You don't need to understand what Schroedinger's equation actually means. You just need to run the computation and accept the answers. With tuning, you just push page up/down until the exhaust tells you that you've got the fuel right. The VE can stay hidden behind the curtain like the Wizard of Oz and you'll never need to know what he looked like.
    • The second part yes, the first part about easy VE calculation is something I've seen a few people talk about online.
    • You 100% could do that, would save money on a gym membership lol. But yeah, getting a cordless orbital sander will feel priceless coming from doing it manually.  Good luck with it mate
    • I initially was going to do the whole car with a block then realised, it would be a bigger monster of the job 😂 I guess that's all part of the learning process. I appreciate all that advice, I think I got a good idea on how to tackle this whole job.
    • I admire your efforts with the scuff pad.  As a mere mortal, I use this for the baulk of my sanding work- https://sydneytools.com.au/product/milwaukee-m18bos125-0-18v-li-ion-cordless-125mm-5-random-orbital-sander-skin-only Yes you can easily create a low spot while sanding. There are 2 types of filler, 1 part of 2 part. The 2 part filler will get used for large corrections and the 1 part filler will get used for pin holes and areas that only need slight filling.  Depending on how zealous you are with the sander (very easy to do with a power tool) or if you are chasing rust etc, yes those low spots will need to get filled or you will end up with a very obvious defects in the paint.  Using the guide coat and large sanding block, high and low areas will be revealed (watch youtube videos for a good visual on this). Its up to you if you think its worth the effort to make the car completely flat before you spray it (you make it flat by filling the low areas).  At the end of the day, it comes down to time. The end result comes from the level of prep put in to the car. If you want a perfect result, you have to put in the time during the prep stage or else it will be impossible to achieve a perfect result during the spraying process.
