Hey i just bought another car so my project is going to have to go as there is not enough room at my place for my this car, my new car, and my work car, so unfortunatly one has to go. (plus id like to pay off some of my loan :ninja: )
Ok here it is:
1992 S13 Silvia
- RB20DET Conversion (Engineered) (Timing Belt Has Been Changed)
- Topmount Manifold
- T70 Turbo
- Braided Oil Feed Lines
- 38mm External Wastegate
- 3" Turbo Back Exhaust
- Silicone Intake Pipe
- Simota POD Filter
- Custom Plenium Chamber (Front Mounted Throttle Body)
- 600X300X80 Front Mount Intercooler
- Custom Intercooler Pipeing
- Trial Blow Off Valve
- Fuel Pressure Regulator
- Bosch 040 Fuel Pump (about a month old)
- Oil Catch Can
- Button Clutch
- Koni Adjustable Shocks
- Adora Lowered Spring
- Slotted Front Brake Rotors
- Locked Diff
- Widebody Gaurds front and rear (front gaurds are vented)
- Custom Respray (blue with purple pearl, black bonnet and mirros)
- Bonnet Pins
- Alarm and Immobeliser. Has remote start, LCD keyring pager, shock sensor etc.
- Smoked Series Gauges in pillar pod (Water Temp & Oil Temp)
- Boost gauge mounted on dash in cup, plus an extra cup which was for oil pressure but my gauge broke.
The back seat has been removed and fully carpeted set up for a sub install. Does how ever come with the back seat and everything else. The car also comes with standard shocks and springs etc plus extra stuff i have laying around the place like the standard front gaurds etc. Also comes with left over paint + the paint code.
Other parts which will ALSO COME WITH THE CAR are:
- RB20DET bottom end, Bored out for 50thou oversized forgies. Has crank and sump + extra bits.
- Shot peened rods
- Copper head gasket
- Vertex Side Skirts
Runs perfectly, starts first go every go, doesnt miss a beat. Serviced every 5000K with MOTUL Turbolight.
Has Long rego. About 10 or 11 months or so.
Im sure there is probably stuff i have left out but if your interested come have a look for your self.
If your interested give me a call on 0402 756 302 or email me [email protected]
Price $9500.
Edited by osiris23
    • Connected to plenum towards the rear end. Yes, absolutely required for the ECU. Even Nistune can't save you if you don't have it.
    • Can confirm solenoid makes no difference. I finally removed the solenoid and the wire off my engine loom and there is no issue with boost. Keep in mind, this is the solenoid, and I've got a Nistune. After the boost controller, I ran the car for a day with the solenoid unplugged - no issue. So then I just ripped the whole thing out. Like @GTSBoy mentioned before, the ECU just sends an earth signal for the 2-stage boost. And looking at the wire going into the solenoid, that just had 2 standard wires and did not look important 🤣 As for boost sensor: I saw somewhere that the vacuum line the gauge uses is at the back of the engine on the driver side. I never touched that but assume ECU uses that??? (maybe? Just assuming)
    • I still remember it trying to rip the steering wheel out of my hand when I put it into a 4wd power slide lol
    • Im also amazed how well Attessa holds up to all of the abuse. Especially with the burnouts and crap you guys used to do at Texi!
    • True! I think I'm closer to 06 with the cameras in phones being out there more. And the nearly impossible to use internet web browsers. Or paying for ring tones... Man I hated when we couldn't just compose a ringtone on a Nokia anymore! These days I just hate it if my phone rings, beeps, boops, or vibrates!
