My car key is really worn out to the point where it only sometimes works in the locks. its the same on both doors, boot and ignition.
Rather than replace all the barrels as they are still fine can you get a replacement key from Nissan? the key has a number on it can a key be orgered for it and how much? or is there anywhre that can cut me a replacement to the original specs?
the car is an import. so don't know how helpful nissan australia will be.
Any one had any experience with this?
https://www.sau.com.au/forums/topic/133235-replacement-factory-key/
You are actually able to just get the key cut at any GOOD key cutter..
DON'T GO TO SHITTY KEY SHOP IN A MALL..
I went to 2 - one of which refused to cut it becuase they kept telling me my R33 one had an immobiliser chip in it (which they don't) and the other said "it won't work, but i'll do it anyway) - he did a shit job and surprise surprise it didn't work..
Look up a decent locksmith that you can go into and get it cut, otherwise - get nissan to blueprint it off the key id and they can get it cut I believe.. mine cost $7 from a security store..
Edited by Links
yeah I had one cut in a mall. did not work. at least worked occasionally.
the nissan blueprint sounds the go I have the key number so should be sweet. has any one had nissan do a key for them?
Had the same issue with my 34 because it only came with one key (has chip in it) when I imported it. Went to Nissan dealerships which was a waste of time, one even offered to get me a copy from Jap for $400. All you need is like the others have said, go to a GOOD key cutting place and they should be able to find the right length blank and a copy. The problem I encounted with those ones located in the malls are that the length of their blanks arent long enough. EVEN if you have a chip in your key a copy one will still work (providing you have an aftermaket immobiliser?), because mine did at the end of the day only cost me $7.
Just take your existing key to a locksmith. He shouldn't have any problems cutting you a fresh key.
Is the key that you have now an original nissan key?
If so there should be a number on it which usually consists of a letter and/or four numbers eg. X1234. Nissan codes have an X before the numbers usually.
If you have that code, you don't even need to bring your key in, but bring it in anyway just to make sure.....
Even if you don't have the code, he should be able to 'read' the cuts on your worn key and cut you a new one.
Don't go to the guys that in the middle of the mall who can fix you shoes while your at it. Go to a locksmith.
If you go to a dealership, they could end up charging you extra on top of what the locksmith charged them, or they might order a genuine key blank which isn't cheap and totally unecessary.
Aprrox cost: Shouldn't be more than $30 for 2 keys. Depends on what the locksmith charges.
the problem is that if his key is too worn to use, then there's going to be no point copying it as the copy will have the exact same pattern as the worn original
you need to either
- go to nissan and get them to make a new key based on the barrel
- get a new barrel and key
you need to either
The point that I was trying to make is that the locksmith will not simply duplicate the key. Rather than duplicating the key, the locksmith can use the key code or read the cuts on the key to cut a new key.
They use the code to crossreference with the exact cuts of that key, they then use a machine to cut a new key as if the was made from the factory.
So in the end, you have, not a copy of a worn key, but rather a brand new key with brand new cuts on it....not worn cuts.
If the locks are fine there should be no need to pull them out. In most cases, worn keys are the culprit.
Depnding on who you talk to at a locksmith shop, you may have to make the point that you don't want a duplicate, but that you want a new key because they don't work too well in your locks. Don't talk to the counter chick, you can talk to an apprentice, but a tradesman would be best.
Cheers :P
EDIT: extra info
Edited by KeyMakeR33
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
    • from an old insurance company i was with (Budget Direct) I had someone roll back into me at the lights got them to pull over. Got a picture of thier licence with address, had a dash cam video and, thier phone number. But only had 3rd party on the shitbox i was driving. insurance did nothing, cops wouldn't do anything due to the value of the damage (under $3000) so i just had to suck it up and go to U Pull It.
    • Small Update on the Exhaust Situation A 200-cell cat was a bit too expensive for now, so I had the exhaust shop fabricate a new exhaust from the cat to the rear and an exhaust tip. I went this route to avoid cutting into the original exhaust and keep it intact. It’s essentially straight-piped, and the sound is noticeably different. The exhaust tip came with a silencer, so if it gets too loud, I can easily install it to tone things down slightly. Right now, the car bangs and pops like crazy -- which I personally love. In the future, I might add a resonator or a 200-cell cat, as niZmO_Man suggested, but for now, I’m really happy with how it turned out.
    • And that's a massive problem, because deadshits will deadshit and give you false details. At least in these days of mobile cameraphones, it is trivial to take photos of any ID they are carrying at the same time as the 300 photo extensive documentation of the state of the vehicles that I recommend even for minor incidents. And you get photos of the person's face, any visible tatoos, etc etc, while you're at it. Then you try to avoid mentioning that you're fully capable of making explosives of various power levels and will wreck their shit if you are forced to hunt them down.
