Hey guys,
Havent posted here in a while but ive been struck with abit of a query. I have an S15 which has a T28 BB Turbo standard.
Now i went to a dyno day and also went to get the car dyno tuned with a pfc.
The tuner said that it wasnt making enough top end power, being short 10-15rwkw with most s15's hes tuned with the same mods. So he is puzzled as to why and so am i! He said car was running healthy too, so it didnt show signs of cylinders gone etc, however I havent done a compression test. Mind you, he is a popular tuner in sydney, and has tuned my old R33 when I had that and had no dramas.
Here were some of the things he noticed while it was on the dyno:
1) When winding the boost up, it really didnt yield any more power. I have 2 boost controllers to try out and both of them showed no extra response on the dyno
2) The Intercooler piping going to the turbo was coated in oil
So are these signs that the turbo has gone bye bye or is about to go? If not, what can cause lower figures in terms of motor problems?
Im very puzzled and just trying to work this out. Any help or input would be appreciated. I dont have the dyno graph either cause I dont pick up the car till friday. Car has all the supporting mods to at least reach 190 - 200rwkw and the car only pushed 180rwkw
Edited by Mr_G
https://www.sau.com.au/forums/topic/133265-turbo-busted/
more boost doesnt always equal more power. this is only true when you are still in the effeiency zone of the compressor. if its only 10rwkw who cares. its hardly anything significant. if the turbo was shagged i would expect it to be more obvious. lots of lag, squealing coming on boost, smoke etc
https://www.sau.com.au/forums/topic/133265-turbo-busted/#findComment-2469433
Thanks for the replies guys. Ill be going for a comp test next week just to put my mind at ease.
As for the manifold, it was changed to one of those stainless items that you get off ebay cause i got a good deal on it, however I still have the standard one just in case.
Ill be replacing all the vaccum lines, will be taking off all the IC hoses and placing them back on.
The pipe that is covered in oil is the one that goes from the cooler to the turbo. It has nothing else plugged into it, so i assume the oil comes through the turbo somehow?
https://www.sau.com.au/forums/topic/133265-turbo-busted/#findComment-2472430
Got the car back, heres the graph.
Please critique your suspisions regarding the turbo.
From looking at the boost curve, it seems as though the actuator could be faulty?
But from driving it now compared to what it used to be, drives a whole lot better indeed :(
If the turbo is on its way out, Aarron from Sliding Performance will be getting the hi-flow job :O
https://www.sau.com.au/forums/topic/133265-turbo-busted/#findComment-2475608
looks alright to me.
the boost is dropping away as you can see, so power is going to drop, get it to hold boost and it might fatten up a bit at the top end, although that may not be too easy if the turbo is starting to drop out of its efficiency range.
could be a gazillion reasons why the power is 10kw different to other cars, i wouldn't worry to much.
https://www.sau.com.au/forums/topic/133265-turbo-busted/#findComment-2476281
Yeah your EBC is not doing its job of holding the boost. I wouldnt say the actuator is stuffed beacuse its still holding 14psi at 6500rpm (my old stock turbo'd S14 could only hold 11.5psi by then lol)
I wouldn't worry about another 10rwkw. Thats only what.. a bit more than 5%? Thats nothing, so long as your happy with the car!
https://www.sau.com.au/forums/topic/133265-turbo-busted/#findComment-2476723
Thanks for the replies guys. At least ive narrowed my problem to be something to do with the turbo and not the motor.
But the mid range gain is very impressive. This was in combination with an adjustable exhaust cam gear. Now when it comes on, especially in the wet, its lights em up easy!
Im pretty sure from looking at the graph, the actuator is busted. Im running a turbosmart boost t, which holds fine on my friends car, but my car, doesnt seem to hold as fine :) So thus, i think the problem is the actuator.
What do you guys think of this theory? Although there is the possiblity that the turbo could be abit busted, causing the eratic boost curve
https://www.sau.com.au/forums/topic/133265-turbo-busted/#findComment-2476826
Your wastegates fine. When that screws up, which mine did I had no boost at all in the top end.
I wouldn't worry too much about the power figure. 186rwkw is about right. Mine has made between 187-195 on the same dyno on different days on the same boost setting. Just see if you can get the boost a bit more stable and your set. All good.
Having a bit of oil residue in the pipework is pretty normal. As someone else said it will just be the head breathing.
As for the comment about sr's cracking pistons at 190rwkw- anything is possible but it is the common consensus that a sr20 if tuned properly will last forever with <=200rwkw. 200-250 is leaning on it and beyond that things start to break. That said the GT Autosound drift car (HPI) which is now Christian Pickerings drift car makes 306rwkw with a stock bottom end!
https://www.sau.com.au/forums/topic/133265-turbo-busted/#findComment-2477224
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
