That white car did a superb job of avoiding the dude who lost it next to him.
The VW (think it's a vw?) one just looked comical... like something from Mr.Bean.
The road looks very wet in all images from that camera.
At least they've got the crash barrier in the right spot.
*as there are a few videos in this thread now, the above comments were in relation to the one that JUNR34 linked to
http://www.youtube.com/watch?v=Z1udsG3LUUg
haha this was on High Octane 4, they cut the best bit out though ;) on the DVD there is a hesterical woman that runs over to the car.
yep, sure is. i saw it when i rented it, crazy shit. due to the nature of High Octane i thought it was some sort of joke, i laughed at that chick screaming when i first saw it until i realised what happened.
hah that bus is wicked
the last car that rolls seems to shit something outa the exhaust once its done
LOL at that tunnel of death vid.. the 2 trucks crash and flip and the first thing the guy that stopped behind them can think of is to signal left and try and get past them.. like literally 3 seconds after they had flipped
haha, i noticed that too. I guess they don't want to hang around to be witnesses :D
That bus is nuts. Actually I thuoght he did a good job controlling that back end. It coulda been far worse....
agreed, i thought the bus driver did damn well considering the situation
    • I'm interested if anyone agrees with what you've said, and can give a good reason. Temperature of powder coating should be below any temperature you'd use to alter the wheel structure.  Powder coat typically 200 to 250. Annealing if that's what people are claiming would be occuring, starts at 300, and depending on the alloy, can need even up at 400+.   That's the only part I can think of that could cause an issue that people are believing it's from the rim losing hardness and becoming too soft.
    • Negative probe should be on the cars chassis. Positive on the wire.   Start as said above by unplugging everything (unplug the lights, and switches. Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch. If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.   Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.
    • Anyone know if it's a problem to powder coat forged alloy wheel centers (Rays/Volk GT-C). some say it's bad and can damage the alloy, some say it's not a problem.
    • Hey guys, I'm reviving an old post but I'm finally getting around to working on this now. I removed the battery to get a better look at the wires and i traced the wires from the headlight to the fuse box in the engine bay, but the wiring looks fine? The wiring for the R/H headlight is 3 wires and then is bundled up with the large diameter wire that goes underneath the fuse box. I didn't take it apart yet. I know you said that its a short circuit somewhere between the fuse box and the headlight. But could it be the headlight switch on the dash? Also, i pulled out my multi-meter and set it on the Ohms, but i'm not sure where to put the negative probe and the positive probe.
    • I have a 2 lt in Sydney. It was fitted on a R33 GTR, not used for several years . If you are interested email me on: [email protected] I'm not on this forum much .
