  • Replies 40
Even though my one is cut; I am willing to let it go complete with the barrels to all the locks in my 34 :) All for the discounted price of $600.00 (without barrels); or $1000 (whole set)
I bought a nismo key, and then I put the car on the dyno at UAS and this happened:
http://video.google.com/videoplay?docid=-9105943383537776086
I will sell my nismo key for $700. It's still uncut. Maybe if you buy it and get it cut your car will make even more power... :D
LOL... nice 220rwkw+ after the nismo key mod :D
btw, nismo knock off keys on ebay.. they look hell ugly though.
270rwkW + :D
http://www.notonmonday.com/images/myupgrad...T30rPSI_web.jpg
Buy my key :) it's good jah. $700.
Just go find the factory in China where Nismo went to get those keys made, get them to make the minimum requirement for a one-off run (could be as little as one), give them a little cash prize for keeping it quiet, then go whack off rigourously admiring you're status improving work.
Even though my one is cut; I am willing to let it go complete with the barrels to all the locks in my 34 All for the discounted price of $600.00 (without barrels); or $1000 (whole set)
ROFL righteo..
keep dreaming buddy,
ill keep mine as a souvenir :P
Edited by whyte
also 1.2 mil for a HKS oil filler cap
http://www.nengun.com/catalogue/product/786
I HAVE 2 I CAN STOP WORKING NOW :P
ITS JUST A KEY GUYS COME ON Y DO YOU NEED A NISMO KEY !
fark... i got 2 oil filler caps too! score! lol
someone should have a word to them about their odd way of saying "item not available".
    • That's not a transistor --- it's marked ZD1 which makes it a zener diode. As to what the breakdown voltage is, not enough there to divine.
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
