Regretful sale-moving
Nissan r32 gts-t type M Manual gun metal grey 92-93 spec (late 92 model)
This is an A1 example of an r32 not a ratty accident repaired car.
Only aussie owner.Imported 3 years ago personally.
Positives:
Engine idle's like a lexus,never thrashed,NEVER driven hard.Yes i drive like an old man... :ermm:post-21850-1157596097.jpgpost-21850-1157596553.jpg
My mates S15 engine sounds like a truck compared to mine!
Mods done in japan:
HKS pod filter
Cat back exhaust and top of the line muffler.(forgot the weird japanese brand)
Genuine Full GTR bodykit including rear wing-not a crappy imitation bar
GTS rear pods
Dark window tints
Raybrig fog lights with remote control!
Mods done here:
Full Tein hr coilovers
Dump pipe
High flow cat
Front sway bar
Front adjustable castor arms
5 spoke rare 17'' rims: a-tech monoblocks with falken alpha rs tyres made in japan
Brand new 2 month old heavy duty clutch exeedy
Brand new slave cylinder (clutch)
Brand new master cylinder (clutch)
New timing belt done at 108000kms
New spark plugs
New water pump at same time.
New speedo cable
New optima dry cell battery 3 months ago
Pro sound system install
Machined front discs
Bendix pro pads front,and rear
All electronics and lights etc work flawlessly
Nismo gear shifter
Projector front headlights-easily converted to xenon
Japanese seat belt extension arm-ultra rare!
Had done 90000kms when arrived.Now with 128000 Genuine kms
Always use 98 shell optimax
Allways used NISSAN 7.5W 30W oil and oil filter
Just serviced.
New airconditioner r34a gas and pipes/condenser
Full imobiliser with keyless entry tracker
Recipts to back up.
Negitives:
Small stone chips on front bar ( barley noticeable)
One of the best examples of a 32 gtst (if i do say so myself)
Asking 15,000 O.N.O
Genuine offers and intersest welcome,NO TEST PILOTS or tyre kickers,i dont have the time or insurance cover for this.Just give me a call to arrange a time.Details in post below.
Edited by cookie--monster
https://www.sau.com.au/forums/topic/133323-sold/
sure has...i will be renewing it in late december...if i still have it by then-i just put it on car sales and have had a very intrested buyer.i put the price down too.
will take off rims and stereo to lower it further still if needed.
https://www.sau.com.au/forums/topic/133323-sold/#findComment-2583252
Guest
    • Connected to plenum towards the rear end. Yes, absolutely required for the ECU. Even Nistune can't save you if you don't have it.
    • Can confirm solenoid makes no difference. I finally removed the solenoid and the wire off my engine loom and there is no issue with boost. Keep in mind, this is the solenoid, and I've got a Nistune. After the boost controller, I ran the car for a day with the solenoid unplugged - no issue. So then I just ripped the whole thing out. Like @GTSBoy mentioned before, the ECU just sends an earth signal for the 2-stage boost. And looking at the wire going into the solenoid, that just had 2 standard wires and did not look important 🤣 As for boost sensor: I saw somewhere that the vacuum line the gauge uses is at the back of the engine on the driver side. I never touched that but assume ECU uses that??? (maybe? Just assuming)
    • I still remember it trying to rip the steering wheel out of my hand when I put it into a 4wd power slide lol
    • Im also amazed how well Attessa holds up to all of the abuse. Especially with the burnouts and crap you guys used to do at Texi!
    • True! I think I'm closer to 06 with the cameras in phones being out there more. And the nearly impossible to use internet web browsers. Or paying for ring tones... Man I hated when we couldn't just compose a ringtone on a Nokia anymore! These days I just hate it if my phone rings, beeps, boops, or vibrates!
