depends on what power output your trying to reach, to me on a forced induction motor, this would be the last thing to do to gain horsepower
port matching is more important.
but if your not removing the head for another reason, it sounds like it would be a waste of money for little gain
https://www.sau.com.au/forums/topic/133339-head-porting/#findComment-2471621
What Craved says is probably not wrong, but I did do mine when head off for other reasons but unfortunately did other stuff as well so could not measure gains. Cost was about $850 inc new valve stem guides and seats.
Will be dynoing again soon so we will see if it could have contributed in some way if I get some decent numbers.
https://www.sau.com.au/forums/topic/133339-head-porting/#findComment-2471637
hahah my english no so good today LOL - last line should have been as below :
but if your not removing the head for another reason you could consider it if you have the money
it sounds like it would be a waste of money for little gain without having alot of other supporting mods and pushing flow limits of the std head ..
:O
https://www.sau.com.au/forums/topic/133339-head-porting/#findComment-2471693
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
