Just trying to confirm something.
I got my car tuned with a z32 AFM that up until that day had been sitting in my garage for about 18 months and I've just found out had been unused but presumed to work for quite some time before then.
Anyway, the tune was good, it ran well but over a few days it seemed to deteriorate and I put it on a dyno where the air/fuel ratios went under 10 and it pinged.
I have since been steadily dropping the boost to now 7psi to stop it pinging.
The z32 AFM I believe maxes out at 4.5 volts.
I have seen it at 4.4 volts at 5000rpm with as little 10psi so it has been suggested that the AFM is dying or at least has something wrong with it.
My question is:
If we are right about the AFM showing far too much voltage for the actual air flow, it makes sense that it would be overfueling but can overfueling cause it to ping? Or is something else up?
https://www.sau.com.au/forums/topic/133359-can-overfueling-cause-detonation/
Mine was running in to the 9's (flat lines at 10 on the dyno as thats as low as the wideband reads) and there were no signs of detonation.
Sounds strange.
I gather you are running new fuel? Its quite possible the old stuff went off as it is 18months old. :O
Z32 at 4.5v. What sort of power are/were you making?
Mine hits 4.3v on the standard turbo running 10-11psi.
well. it must of been making some power to reach the limit of the z32 afm.
to much fuel can cause pinging. not directly, but by carbon buildup in the cylinders. this glows and causes pinging. not detonation.
this is a pretty obviouse question but there isnt any air leaks is there?
also worth checking is the timing. if the cas hasnt been done up tightly it can move and the timing can change.
in throey. if its dirty it will take more voltave to keep the element hot. given the same volume of air.
coz the dirt will be insulating the film.
give it a clean(if its dirty) this will restore it to the factory parameters. if that makes any sense.
also oiled type air flow meters are no good for longevity on any hotwire or thick film afm (z32) it oils up the element and the dust sticks to it.
Wouldn't that mean less voltage?
If you had an air leak in the intercooler piping, or a venting bov opening, the afm voltage will go high, as will turbo speed.
Well with the old ECU, auto and stock AFM I was making around 255rwkw.
Then I did a manual conversion and put a pfc and Z32 AFM in. Tuned on a dyno that seems quite happy it made 300rwkw. This was at 11.8 A/F ratios I'm told.
Tried to run it on a dyno I knew and it ran 225rwkw, pinging and rich as feck. Didn't get too close to redline cos of the pinging.
Cubes - is that standard turbo but RB30?
Fuel is new and fine. 3 types tried.
I don't think there are any air leaks but I will check tonight.
The pinging doesn't seem to happen with heavy boost low to mid rpm, more like any boost high rpm, like over 5000.
My theory at this stage is, AFM tells PFC there is much more air than there really is, PFC puts lots of timing and lots of fuel in.
The only other thing I can think of is that the lambda sensor used to tune it was out and something is wrong with the tune although that wouldn't account for the pinging since it wasn't pinging at all when it was being tuned and on my test drive (and I gave it a good quality test drive).
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
