A GTR with the equiv usual mods (exhaust/ECU/boost etc) to the GTS-t should be low 12's if you know what your doing.
Hell, i know of one that dipped into the 11's on stock turbos and normal rubber... so mod for mod the GTR will always be a fair way infront of the GTS-t
Weight isnt as much of a disadvantage as 4WD is an advantage :laugh:
  • Replies 59
Posted Images
I don't know i always assumed that with a good full turbo back exhaust with dump pipe and hi flow cat, front mount, good cold air intake setup, power fc, fuel pump and a bit of boost and you would be in the 12s. Am i wrong for thinking this???
Well look @ Adrians results (2rismo)... does that not answer the question...? :D
Maybe Adrian can give a run-down of the mods that car had?
Daniel - IIRC the car adrian pilots was rev210's old car, and there is a link in the FI Guide to his project thread from a few years ago as it was very informative for its time.
http://www.skylinesaustralia.com/forums/in...?showtopic=9445
cheers
Well look @ Adrians results (2rismo)... does that not answer the question...? :wave:
cheers
It's my car - rev210 sold his R33 (in W.A.) and I've never even seen it! I bought his old Nitrous kit, maybe that's why you're confused.
I'll post specs later.
Adrian
The car had most of the usual stuff every other R33 GTST had. The Nitrous made 1 second difference.
Things like good tyres (not slicks) and LOTS of practice are mandatory.
Things like weight reduction and 300kW are not.
Adrian
Thats probably where im muddled then :wave:
Only been to the drags once got all the supporting mods but have a Safc no power fc. Managed a 13.6 @ 105 with a 2.3 sec 60 foot time, on a 30 degree day. The run I had was against a stript out BMW M3 with track racing tyres and few other mods. He ran a 12.9 @ 105 with a 1.8 sec 60 ft time. As you can see from the time slip there was nothing in it other than the launch I actually felt I was slowly reeling him in 3rd and 4th gear.
From this experience I think you would need some really good street tires with 60ft time bellow 2.0 to break into the 12's. So it is very possible
That was about the best I could do with 17/45/235 hankook silica tires.
cheers
One customer ran 13.0@113mph with exhaust,China cooler.Safc.
No changes made for the track and ordinary budget tyres.
113mph was stock turbo? Bloody excellent if so. Quickest I ever ran (without the bottle) was 111mph and this was in perfect conditions.
How fast do u guys think a r32 would go with 213rwkws? i was thinking about 110mph and a high 12 if i was lucky
The setup is is for circuit with 18x7.5s, 225/40 s-03 rubber and all the suspension parts from SK's GB
Edited by 2630GTS
I didnt see anyone with r32s posting hmm, ill re read
Edit: Ok i re-read and understand we are talking r33 with rb25 and stock turbo.
but the stock turbo on a rb25 can make almost as much as the 213 im making with bolt on turbo.
So i thought it wouldnt be a bad place to ask, considering most of they guys in the thread have actually taken there car to a dragstrip.
Never mind sorry to get off topic, its just ill never drag this setup and pretty sure it would have a high 12 in it, was just looking for a yay or nay :(
cheers tho
Edited by 2630GTS
13.1@105mph on 205/55r16 $50 tyres to pass rwc
with better tyres (non slick) i will for sure run 12. But traction is an issue with these street tyres.
Edited by LTHLRB
hey bit off topic too sorry.
ur running 7.5inch rims.. how wide tyres can u fit?
but u think u can fit 245 on 7.5rims? :no: im really hoping to.?
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
