  • Replies 129
Posted Images
Got mine today - very happy with them! (But like someone said - the 'wrinkly' could be waaaay more wrinklier!) Have done the drivers seat at this stage, pics attached
Hor-f**king-Ray
kinda got mine but didnt, no one was home to sign for it so its at the PO, mum is getting it for me tomorrow :D put them in saturday
YAY
Finally got my covers & seats ....
i've got passenger & back seats done as well as the centre console (they did it for me), l'll be doing the drivers on sat/sun, so l'll post up pics then.
But DAMN they smell good, and look HOT!!!
Guys please take care installing the covers they are very very tight...patience needed..
Here are some pics ultimate sent me of head rest installation, hope it helps some of you..
that's wicked!! wish I got onto it!!! PLEASE let me know if you get another group buy going, otherwise I may have to look into it myself...
Keep the pics coming!
Nice seats those ... look even better in my car. :woot:
But great pics Jetdat ... my only concern was this part of putting them on, so now l won't need to worry
Edited by -FUZZY-
I have actually left the plastic thingos that adjust the headrest height under the cover - I just made 2 small holes and poked the headrest poles through (adjustment is made by pinching the plastic thingo together through the cover) .... I think that looks better.
Back seats were very easy about 10mins each side. Fronts seats are a bitch to do on the R32 GTR seats. The fit for the back rest isnt so great, the hole at the top looks pretty ordinary and right at the bottom is too loose. But in all still great value for money
Hey mate, can you send me some pics so i can show ultimate this problem?
must say a big thanks to Jetdat, the organisation and information presented thruout the buy was exceptional. very happy with how it all went.
Cheers mate :)
LOL are you shirtless in the background ?
Do i sound like a man or does my hand look like a mans hand?!?!?! :)
Thats my bf in the backround.. lol..
Agreed!
I did the same mate, I also left the lubar support under the cover I never adjust it anyway
and D I F yes they do look like man hands :)
just kidding
cheers
    • Which is why I didn't mention that hardness testing, and specifically mentioned the bore and deck thickness testing. Yeah, not really. The bore temperature will be a lot more even around the top half inch or so, where the material distribution is dominated by the deck, and which is the only place where the bore surface temperature heating any gas in the cylinder is likely to have any effect on detonation. Think about it. Another inch or so down the bore, you might have a hotter spot. The gas there might get a bit hotter, then the piston rises squeezes that gas away from there at high speed and mixes it with other gas from nearby. Instant dilution of the problem. I'd be surprised if it was an issue at any time other than in racing engines or OEM dev engines being run at the ragged edge of tuning. Say what now?
    • https://dsportmag.com/the-tech/education/engine-tech-material-hardness-testing/ The PRP testing on block hardness I'm not sure how much it actually can be trusted. The thinner cylinder walls on RBs is a bit of a problem vs 2JZ but it really depends on the design goal. Siamesed cylinder bores like a 2JZ cause uneven cylinder wall temps too, which means a bit of distortion induced by that + the hotspot can affect knock margin. Something that actually gives me a bit of pause with the PRP block, whether super thick cylinder walls are going to keep it from being drop-in compatible on an otherwise OEM rebuild.
    • Yeah very valid point. I am waiting for one of the other tuners to come back from vacation so he can help me a bit when the cat is installed again. In the meantime I am going to finish up my polishing and ceramic coating that I have started myself.    N45 Dr Beasley product is highly recommended for a paint primer / polisher. Using this EXO Gtechniq also for the ceramic but next time might use the light serum before hand also. Looks great.
    • Running rich in conditions where it shouldn't probably won't do great things for catalytic converter lifespan. I would fix that sooner than later.
    • Yes, important point. Watch the Motive videos with Herman thickness testing the bores and deck. You do not want to push the unlucky (thin) block as hard as you can push the average block.
